Starter relay options s2 xj6
So I read this http://jaguarspecialties.com/tech_tips10.asp about the upgrade to a readily available starter relay. However it seem the Bosch 032204150 isn't so available. Anyone know an option that's available at autozone/O'Reilly's/Napa/advanced? That Bosch is out of stock so I assume its a parts number change. Thanks!
Received 10,944 Likes
This might be of interest
https://www.jaguarforums.com/forum/x...-relay-183619/
I'm using the Chrysler relay on a Series III but I'm 99.9% sure the Series IIs and IIIs are the same as far as the starter relay goes.
Let's hear what others have to say
Received 2,399 Likes
It is my belief that any generic four or five post unit of 30 or 40 amp capacity will do it. If you get a 5 post merely don't use the spare.
The posts are two for the load circuit and two for the trigger circuit .
I robbed one from a driving light installation kit. Just fine.
Some where in the archives is a translation kit of Jaguar wire colors to the post markings.
Carl
Carl
Yup!
Assuming typical/generic terminal designations:
Terminal 30 - solid brown wire (12v constant)
Terminal 87 - white/red to starter
Terminal 85 - black or black/green from neutral switch
Terminal 86 - white/yellow from ignition switch
Eurowerks
01-12-2015 05:42 PM
Saemetric
12-05-2014 05:56 PM
