Steering rack: refurbish the original or buy new aftermarket
Old 09-16-2021, 07:47 AM
iramphal's Avatar
Ascanio1, Could you let us know where the Alicool condenser comes from and what the part numbers are? I'm looking for a similar "drop-in" unit with fans etc.
Ian
  #102
Old 09-16-2021, 08:01 AM
ascanio1's Avatar
Originally Posted by Jagboi64
A bit of rust on the outside isn't a reason to condemn a compressor, they are made from very thick steel. The original compressor was called an A6, made by the Fridgidaire division of General Motors.
... CUT ...
Thank you Jagboi! This is an impressive history of parts of our Jaguar A/C system!
The only real "drop in" replacement would be a Sanden and it's associated brackets from a 6.0 V12 XJS. I have no idea if those parts are still available, as relatively few 6.0 cars were made.
This could be an option but I doubt that the brackets, pulleys, belts, etc., would simply drop-in. If I have to ask the mechanic to come up with modifications, then it defeats the object of my idea to reduce to a minimum the modifications.
... CUT ... I don't believe you can buy an original anymore, that that's why I'm urging caution before changing the compressor, if the current one is working. If the system is being opened up you can change the oil for fresh, there is a drain port on the bottom.
Given all your explanation, I come to the conclusion that your recommendation might be the best course of action, at least for this specific component, the compressor. I will try to follow this advice but I might have to renegotiate labour costs.
Just for your information, I face the challenge of having negotiated a very low ($1,800) labour charge. This was based on a few understandings:
i. I would deliver all replacement components with the car so that he could complete all the work in one go and I would not take up space in his workshop, waiting for parts;
ii. He would not be required to inspect, or repair, any of the old components;
iii. The car would not go in and out of his workshop or occupy his hydraulic lifter longer than he considers necessary.
This mechanic has a small workshop and only two hydraulic lifters. Space and lifters are the instruments that generate his revenue and the longer a car occupies either of them, the more it will cost him.
Of course I can ask him to lower my Daimler and move it into storage, not too far, while we decide what to do with each component. Yes, I can break up the repairs in two sessions. But I will end up with a higher labour charge for inspection and repairs, regardless of the fact that, chances are, I might end up having to buy new components anyway! Not only I will waste labour costs but, more importantly, I will keep older parts with a shorter life expectancy which might defeat my initial purpose of (a) saving on labour and (b) replacing components to extend their expected life and increase reliability.
Having said all this, I think that the compressor might warrant a different approach for the reasons that you described. Thank you for sharing your time and expertise.
  #103
Old 09-16-2021, 08:13 AM
ascanio1's Avatar
Originally Posted by iramphal
Ascanio1, Could you let us know where the Alicool condenser comes from and what the part numbers are? I'm looking for a similar "drop-in" unit with fans etc. Ian
Hi iramphal, sure.
The company is this one but, please, note that I cannot offer you the parts numbers as the XJ12 kit is not listed and they build it specifically on order as they did for other forum members who recommended this kit. I spoke to a chap at Alicool called Keith. He confirmed and guaranteed that it would be straightforward drop-in, just as used by other forum members.The price for a radiator with fitted fans and cowl and fan sender switch to regulate the on and off temp is £932 and they will also sell you the whole list of hose clamps, if you send them a list. The fans come with a white connecting block but most people strip these and wire in.
I decided to go also for the A/C condenser, as their aluminium radiators are claimed to have a much greater efficiency than the original brass ones.
I hope this helps. Tommaso
  #104
Old 10-25-2022, 08:12 AM
ascanio1's Avatar
Just an update to inform everyone who helped me that we will be refurbishing the steering rack locally. I am now looking for (*):
i. high pressure hose
ii. all internal parts required for the refurbishing of the rack (local rack refurbishing specialist offered me a very cheap estimate for labour, but I must provide all parts
iii. pump
Daimler Double Six 1992 V12 5.3 LHD (EU not JAP)
VIN: SAJDDALW4CM486688
  #105
Old 10-25-2022, 11:19 AM
Peter3442's Avatar
Received 1,344 Likes on 1,009 Posts
Tommaso, Good to hear that you are making progress. SNG Barratt sell repair kits (basic parts) for £50 to £60. They may need to know exactly which make and type of rack you have and what you want beyond the basic kit. As they have an EU outlet, ordering should be straightforward.
For radiators, Alicool has unfortunately closed, another victim of the economic situation. I have their XJS version in my DD6.
  #106
Old 10-25-2022, 12:21 PM
ascanio1's Avatar
Thank you Peter! I messaged them as they had a few different ones.
In another thread I mention that Alicool went upside down so I am buying from Radtec. Could you help me out, there, for the thermostat?
  #107
Old 10-25-2022, 12:50 PM
Peter3442's Avatar
My thermostats are from a few years ago. I'm fairly sure they were from Barratts. Because of the way the thermostats in Jaguar engines block the bypass as they open, it's better to go to a supplier that knows the requirements, even if it costs a little more. There's probably some discussion on the XJS subforum. Also, I prefer the lowest temperature thermostats; I think that's 75°C.
  #108
Old 10-25-2022, 01:15 PM
ascanio1's Avatar
Good evening Peter, thank you. Yes, I list the options here. Which one is preferable? Perhaps it is be more helpful if you were to reply in the other thread, so as to benefit future forum readers who may search thermostat and cooling systems issues.
  #109
Old 10-25-2022, 01:27 PM
Peter3442's Avatar
I can't find your other thread. What's the title?
  #110
Old 10-25-2022, 01:53 PM
ascanio1's Avatar
EcbJag
04-25-2020 06:13 PM
INDYJAG-84
12-14-2018 06:01 PM
vsol
05-01-2018 12:19 PM
Mac Allan
10-12-2015 11:59 AM
jeansanspeur
10-23-2013 02:50 PM
Quick Reply: Steering rack: refurbish the original or buy new aftermarket
