Steering wheel upgrade on my 82 XJ6?
I had one like the one you were looking at.... sold it. Too hot to touch
when the car had been sitting in the sun.
Got a all wood three spoke one from Grant, you can choose your own center cap, love the smaller OD as the stock "school bus" sized wheels are too large.
Alyn, believe me I considered doing exactly what you did but didn't because... I have all the original steering wheels of every car I've ever owned starting with a 1969 MG-B, then a 1971 Volvo 1800-E, then a 1973 Volvo 1800-ES, then a 1979 Saab 900 Turbo, then a 1984 Jaguar XJ-6, then a 1965 Jaguar S type, all their steering wheels replaced and in like new condition, so you can see why I did not want to sacrifice the XJ-6 wheel. The best steering wheel I've ever had my hands on, is the Saab 900 wheel, though the car was a nightmare.
Steering Wheel
That's quite a collection of steering wheels you have there Jose...(glad I did not keep all the steering wheels from my past cars as storage would be a big problem.) ..however if you trot over to EBAY, you can find all the used Jag parts you want for cheap.
Who wants to bid on old Jag steering wheels ? - no one .
So keep your originals and visit EBAY where for 5 bucks and cost of shipping you can have a Jaguar original steering wheel base to use..(.its only going to recycling anyways) ...so you might as well be the "recycler" and make better use of it.
Jose (01-02-2016)
That's quite a collection of steering wheels you have there Jose...(glad I did not keep all the steering wheels from my past cars as storage would be a big problem.) ..however if you trot over to EBAY, you can find all the used Jag parts you want for cheap. Who wants to bid on old Jag steering wheels ? - no one . So keep your originals and visit EBAY where for 5 bucks and cost of shipping you can have a Jaguar original steering wheel base to use..(.its only going to recycling anyways) ...so you might as well be the "recycler" and make better use of it.
can't find the two Volvo wheels, I know they are boxed somewhere in a mountain of boxes!!
going to contact David at Everyday XJ about a used XJ wheel, but would appreciate some pictures of how you did yours. Thanks!
Happy New Year!!
Jose, you should build a rack for those steering wheels. Maybe something like a coat rack. Maybe a piece of muffler pipe with smaller pieces of muffler pipe for the wheel mounts. Use a larger diameter steering wheel from a 50's era car turned upside down for the stand. A trophy shop can make very small plaques with the year, make, and model of each vehicle so you can put it with each wheel. Plaques are very inexpensive. Be a neat display piece.
Jose (01-02-2016)
Received 2,399 Likes
Warlock:
Given the three choices you had, I'd opt for a bare center, sans wood or leather.
Jose: yeah, wrong part. It makes it easier. But, shaving off a half inch a better tool would be an end mill. short work for a pro machinist. The question does remains as to whether there is enough material remaining to assure permanent mating between hub and shaft. Especialy if the hub is anything less than steel. Alloy???
Roger: I prefer the school bus wheel dimensions. Just habit, I know...
Alyn: Slick indeed. In my project before the Jaguar, I wanted a "sportier" wheel to mate to the Model A Ford steering box shaft. I had a badly detiorated Model A steering wheel. I whacked off the old hard rubber til I came to a slick "spider" in the center. I cut out an alloy adapter and mated what was touted to be an old Jaguar wheel.
Flat drilled metal with a thin fabric covered rim. It had been secured to a hub by screws. A Jaguar owner was delighted to get the hub.
My roadster got a "different" wheel.
Up, in my shop rafters is a 'banjo" wheel of unknown etiology, I wonder????
Naah, not Jaguar appropriate.
Carl
Carl
steering wheels
When I referenced EBAY I really should have recommended David at Everydayxj...he is the best !! (sorry David, getting to be a bit absent minded at times) .
Have always had excellent experiences buying parts from David (as many others have) I am sure that as time goes by, he will be an even more valuable source for the XJ community.
The following 3 users liked this post by alynmurray:
#28
Steering wheel
Jose I don't think I can get pictures of it as it buried under a rubber shroud.
Basically I hacked out the middle of the old wheel, trimmed it to fit the column (cut off spokes) I think I used the Momo adapter for a pattern of where the screw holes had to be drilled on the base. I drilled and tapped it to use the same Momo screws....the Momo adapter came with a ribbed rubber cover - like a bellows,..It was loo long ,..so I cut it down to size and it gives the steering wheel to column location and nice finished look. So you can not see the adapter.
Doug, did you paint that Nardi black or did it come like that? I think the metal finished spokes while great on an XJS or sporty car, don't suit the XJ sedan, the black ones keep the character of the car.
#30
Another question for Doug: What is the diameter (mm.) of the wheel in your car?
#31
#32
Received 10,989 Likes
It came that way. I agree that the black looks good in this application. More towards understatement than bling.
I think the diameter was 14"....but I can't quite remember. Sold the car a few years ago.
#33
#34
#35
#36
Carl, I checked today and the Momo hub is one solid mass with a splined center while the Jaguar hub has a hollow-skirted area before the spline, -see picture-. Alyn is right, the Jaguar hub is better because it was designed for the adjustable aka telescoping steering columm of the XJ and all other Jaguar since 1955 if not earlier. The aftermarket Hubs don't let the steering wheels in both the XJ and the S type go all the way down or forward. Happy 2016 !
#37
I agree with that, aluminum spokes not for luxury sedans. That is why I went with black anonized spokes for my 1965 S type, the grandfather of the XJ, -picture below- but I am still not sold with the Y orientation of the left and right spokes, pointing to 10 and 2 o'clock, they block the tach and speedo. They should be oriented to 8 and 4 o'clock, more like a Peace sign. I went ahead and purchased the wood Momo that David Boger posted in this thread since noone else bought it and it has the orientation that I want. It should work fine in the S type, if not I'm going to be eating a wood steering wheel for a while
#38
Jose:
I plumb forgot the in and out feature of the cars. Mine has been set for over a decade. Actually, as I now recall, I had to use a strap wrench to
free the collar! Same to set it securely.
I never mess with the tilt feature in my Jeep, either.
Way back when I lived and worked in a really hot clime like, Hafrod,
I covered the seat with a towel and another for the steering wheel!!!
When parked in the sun for any length of time.
Never wore shorts.... Cooked or frozen backside never appealed to me...
Carl.
Carl.
#39
Carl, do you mean those rubber strap wrenches used for opening jars, for plumbing, etc.? Yes they are perfect for loosening the scalloped wheel behind the steering wheel when it has been overtightened. Two of those can also be used to separate exhaust pipes and mufflers from each other, to loosen or tighten oil filters...ad infinitum
#40
