Stuck door
So the right rear door on my SIII is stuck closed. The lock wont unlock. So Im trying to determine the best way of getting the door open without damaging the door panel too much. Can the door panel be taken off with the door closed? And how are the exterior door handles removed?
Any help with this matter would be greatly appreciated!!
Received 10,933 Likes
I've removed *front* door trim panels on a stuck door door before without damage....so I suspect the same can be done on the rear.
On a *front* door latch ....might/might not be the same on a rear door....you can see a little nub that swings in an arc. Slide it/rotate it thru the arc of it's travel to release the lock. A screwdriver helps becuase the action is rather stiff.
Exterior door handle are bolted on from the inside. It's all very obvious once you are looking at them from the backside
Good luck
Good luck
Yeah thats what I figured. I may just have to damage the top part of the interior door panel. The Haynes manual instructions are REALLY vague.
99xk8guy
06-05-2023 06:28 AM
Rlover
03-30-2016 10:04 PM
Andrew Fanshawe
09-14-2015 07:40 PM
RaceDiagnostics
09-13-2015 02:22 AM
