Swapping BW12 for a BW66
Just a quick question that will probably turn into a 100 post thread.
Dr Phill and I picked up two series 3 BW66's from another forum member today for cost of the fuel to drive there. One came from a running car.
I have no issues with my BW12 right now but it is the only part of my running gear that hasn't been restored/replaced.
Is it a straight forward swap, and what is involved?
Grant Francis (05-26-2016)
Ya pushing the memory cells now mate.
Bolt up, yes.
You will need a S3, or at a push a S2, flywheel (driveplate to some).
The BW12 is vac modulated, the BW65/66 is cable modulated, soooooo, you will need a S2 throttle linkage rear section with the "double bellcrank" to work the carbs and the trans cable.
Mount at the rear will be OK.
Prop shaft same length from memory??.
Your starter should also be OK, as in mesh etc with the updated flywheel.
I did it on my S Type 3.4ltr, which had the BW DG, the predecessor to the BW12. It was rod modulated, so HEAPS of mucking around to get the cable adapted, coz the S2 stuff I mentioned above would NOT work on the S system.
That BW12 is TOUGH, and is for most part an FMX in disguise. Some innards are hardish to find, but as a cast iron unit, good as they come. They used it behind the early V12's.
Mate of mine went the opposite way with his S2 6 cylinder car, a very long time ago. That was fun.
Bolt up, yes.
o1xjr (05-26-2016)
Bolt up, yes.
Bolt up, yes.
Came with a prop shaft too.
Yep, the BW12 is tough and working well. Track days proved that. The parts I have replaced on it were from an FMX part number(I had one of those in my Falcon 351 coupe and never broke it)
Not planning a transplant right now, just dipping a toe in the water to see what is what. It was an offer I couldn't let go considering the age and availability of spares.
Having done nothing to the trans except a couple of parts, they are worth putting in my stockpile and doing some research.
I'm sure Dr Phill will do some poking around too.
XjeeJ:
Don't think so. Top gear is straight through on either.
But, as a cable driven speedo, the little plastic gear
in the box that drives the cable may differ from one box to
another. there seems to be some tolerance in tooth matching???
My lump's speedo is off a lot. I know how to fix it and have the
device to do it. But, I merely drive by tach or interpret as I knw the error. No tinkering, it works.
Errands today, in the Jaguar...
Carl
Carl
Carl
Carl
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
