Tail, Interior/dash lights 85 XJ6 are off
Received 10,944 Likes
With any lighting faults begin by checking the bulbs and fuses.. And 'checking' includes cleaning away any corrosion on the contacts.
Do you have a 12v test light? it would be helpful.
You've mentioned several different lighting circuits so you may have to diagnose them individually. Some of them might share earthing/grounding points, though...so cleaning the grounds might be the fix.
Do you have the S57 wiring guide? It would be very useful here
i did some corrosion cleaning around the fuses at the driver side and the lights are working now.
But, when I switched on the high beam, it's only the driver side that works whiles the passenger side high and low beam goes off bit when switch to low beam, the two sides low beam works fine.
Where and what do I check to fix the passenger side problem on the low and high beam when high beam is switched?
Interesting side of your submission is, how do connect electric modern car fan if I want to change the existing fan on the engine?
Bullet connectors etc
mikega (05-05-2021)
