Temp Gauge Position
I think my Series 1 XJ6 4.2 might not have a thermostat fitted as it takes an age for the temp gauge to move and when it eventually does, it's no more than 1/4 of the way across the gauge.
Is this suspect and were should the gauge be once the engine is up to working temp?
in a normally operating cooling system, in hot weather, with a/c on, a little above normal. (center to right, all the green area of gauge is normal). If the automatic fan comes on when it should, (past the green area), it will bring it down to normal and the fan will run as long as it needs to, to bring the temp down according to the Thermal Switch mounted on the right bottom side of the radiator.
it could have a stuck-open thermostat, best thing is to replace it but be careful, the thermostat housing studs tend to break when undoing the nuts. Better treat them with Penetrating oil and Rust Blaster for a few days before attempting to loosen the nuts. And even then, go easy, put the wrench on the nut and start tapping the wrench gently. otherwise if a stud breaks, you'll disable the car until you extract the broken stud and replace it.
if everything goes well and all nuts are removed without breaking the studs, you'll need a new gasket and thermostat, and you can apply anti-seize to the stud's threads, adding a stainless steel flat washer and a lock washer before the nut for easier removal next time.
Grahame1972 (01-12-2020)
It is also possible you're having a gauge, wiring, voltage stabilizer or sending unit issue. When I first got my car the gauges were a little screwed up and I found that pretty much all of the wires to the various sending units were badly heat damaged close to the engine.
Definitely follow Jose's instructions and check that thermostat though - a bad gauge won't blow your head gasket.
Jose (08-14-2012)
thank you Mike. I have seen one Series 1 with the same wiring issues you mention. I would try to drive the car for a while and then check how hot the engine feels when you open the hood. If not too hot (Jaguars run hot, I have two), then it could be assumed the thermostat is either not there or stuck open. (almost the same thing).
I know that in very hot countries, people remove the thermostats to keep the engine cool. Considering this car is carburetted, I don't see an issue with removing the stat. If it was a fuel injected Series 3, then there would be issues.
99.9% of people complain about overheating!
Personally I've done the no-thermostat thing a few times in FL although that was with cast iron headed American engines... but in my defense I was young, impetuous and even poorer so the cheap fix was the fix I could afford.
![Icon Lolsign](https://www.jaguarforums.com/forum/images/smilies/icon_lolsign.gif)
the service manual does not tell you to add Teflon tape to the sender's thread to eliminate potential and future leaks!.
![Icon Omg](https://www.jaguarforums.com/forum/images/smilies/icon_omg.gif)
abonano
25
09-25-2015 10:43 AM
