Thanks to member Kudzu
Old 02-20-2020, 06:55 AM
Jose's Avatar
Received 2,482 Likes on 1,865 Posts
Default Thanks to member Kudzu
this is to thank member Kudzu for sending me his fix for the outside Wipers Shaft Rubber Covers.
The fit is perfect and since these rubber covers are NLA from Jaguar, they are actually a better solution for deteriorated covers.
How he came about these? I have no clue.
Thank you Brian.
Mkii250 (02-21-2020)
Old 02-20-2020, 03:57 PM
Mad Hatter's Avatar
Wait what are these? I may end up needing these for my car as well haha.
Jose (02-20-2020)
Old 02-20-2020, 04:15 PM
Jose's Avatar
if you pull the wiper arms from the wheelbox shafts, you wiill see two rubbber domes or "cups" or covers. The rubber deteriorates and falls apart after 30 years. Many cars might not even have them anymore.
Brian found a similar "cup" cover from engine parts, I forgot the actual engine part they are from, but he posted part numbers and pictures in another thread.
Maybe he will see this thread and repost it here.
Old 02-20-2020, 06:32 PM
Mad Hatter's Avatar
I need the rubber bits that isolate that cup from the body.
But.... also yes.... i don't have the rubber between the cup and the wiper either! haha, i didn't even know it existed.
Old 02-20-2020, 06:37 PM
Jose's Avatar
do you mean the gaskets under the aluminium or chromed wedges right under the nuts?
someone else here found a way to make those gaskets too.
Old 02-20-2020, 06:56 PM
kudzu's Avatar
Hi, here's the thread with pictures of the original seals ( those are the BEST ones I found after searching junkyards etc, most were already split in half or gone ) and my replacements made from engine valve stem seals. Felpro # SS13955 box of 8. They do need to be trimmed by about 1/16 off the skirt to fit correctly. I stuck them over the outside end of a 1/2 cpvc water line union ( any hardware store ) to hold it for trimming with a razor blade, you could use a dowel etc.
https://www.jaguarforums.com/forum/x...e-seal-227437/
Hope this helps !
Cheers,
Brian
Jag7651 (02-20-2020)
Old 02-21-2020, 05:11 AM
Jose's Avatar
covering the nut makes the upgrade more finished or "tailored". Being that the rubber is made to be used inside the engine, they should last another 30 yeas..
NICKGTD40
01-11-2017 11:09 AM
flycasterwa
10-26-2015 09:00 AM
JohnBJag
08-12-2014 08:07 AM
jimmiejag
07-17-2014 02:56 PM
g.dover
05-18-2014 12:04 PM
Quick Reply: Thanks to member Kudzu
