Is there a fuel tank removal FAQ?
There's a local guy selling a nice looking 83 XJ6 with a SBC already in it. Says it runs but needs brake work and fuel tank work to be roadworthy. I'm going to go check it out, and have been seeing that the tanks are a royal PITA to work on.
It's not for a daily driver, but if I get it, would like to make it road worthy quickly so I could park my twin turbo Z until weekends or something. 400+ hp cars needing 93 octane aren't so cheap to putt around town in.
Anyways, worst case scenario, if the tanks need to be dropped to be really effectively cleaned, is there a walkthrough on removal of the tanks anywhere? I've looked through multiple pages on here w/o much luck and Google mostly brings up questioned asked on Ask.com about later 80s or early 90s XJ6s and I don't think those would help.
Received 10,875 Likes
This isn't exactly a step by step but there are a few tidbits that might be useful
On Draining the Gas Tanks
In a nutshell it's remove rear bumper, remove lower quarter panels/valance panels, drain fuel, remove hoses and wires, remove filler necks, remove tank bolts/hardware, drop tanks. Not a fun job
Others will chime in, I'm sure, with better info
I've come halfway to taking a fuel tank out, and decided that to wait until the winter because my other tank was good. The quarter bumper is a pain in the butt to get off. Pull up your wrenches and sockets, put down a towel/box/creeper to lay on, douse the bolts with penetrating oil, and get to work. It's a rather slow process that requires you to manipulate the black rubber part of the quarter bumper to get the bolts out. The long section of the bumper does not need removed.
If you pull away the trunk side trim, there's a fitting or two there. That's about as far as I got. If you go through with it, post some pics and feedback!
the step by step instructions for either tank removal are in the Jaguar Factory Service Manual. (not a Haynes or Chilton, but the FACTORY Manual).
one warning in the instructions is that the fuel system must be de-pressurized before tank removal, and the battery must be disconnected. Electricity and Gasoline (in liquid or vapor form), do not mix for some strange reason.
also you can't remove one tank and keep driving with the other, so the car will be disabled.
why de-pressurize? I don't know but I stopped trying to outguess Jaguar a long time ago. Most people do it "by ear", not depressurizing the system, then they end up with one problem or another, that much I know. I replaced one tank years ago, following the Manual instructions, piece of cake, and never had any problems since.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
