These might come in handy...someday.
We all do it. Keep bits and bobs that we think may come in handy, someday.
Whilst playing with Lady Mable, new to me Series One XJ6, I found that she had only one guage panel retaining thumb screw.
Guage panel thumb screw. Series One.
So I needed to make another. Off to the "Good ****" bin.
First to find an imperial 17/43 unf BW or something. I have lots of a metric thread that is VERY close but just not close enough.
I eventually found the right thread bolt, but it was only 32/64 of an 26mm long, so needed to be stretched.
Then the thumb wheel part. Aha! I knew they would come in handy, someday, when I squirreled them away more than 20 years ago. Some genuine Mitsubishi Series One Jaguar thumb screw heads.
OEM Mitsubishi Series One XJ6 thumb screw heads.
Still needs a stand off collar.
Size is spot on, only missing knurled edge.
With the addition of a roofing tech screw grommet as a stand off collar, she works a treat.
Now to find where this wire goes...
I suspect it is headlights.
Headlight rocker switch has three positions. Off. On and ? Only two wires connected. I think loose wire comes from here, but don't want to cook anything.
Received 10,989 Likes
Bosco15 (09-20-2021)
The following 3 users liked this post by redtriangle:
And on the flip side, I'm sure that we have all experienced it, you throw something out because you've had it for so many years and never needed it only to find that within days.....aarrg!
LnrB (09-20-2021)
The Series One has a rocker switch to the left of the headlight switch to turn side lights on. Pretty neat, actually. If you turn the headlight switch on, without turning sidelight switch on, it toggles both switches together.
Doug (09-20-2021)
magnetron
07-15-2018 10:23 AM
