Thick Black Smoky Exhaust then back to normal
Drove 90 miles there and back yesterday, and she was lovely to drive. Same cold start problem, only a slightly lumpy idle though 700rpm in D with my foot on the brake at a red light, and 1000 if I shift to N even if very hot. A new CSI is in the mail to me. Probably a Pertronix distributor and coil plus new leads after that.
I really hope you could check your fuel pressure regulator like Doug mentioned a few weeks back. On my friends 77 XJ12 I have been working on (ohh - over a year now), I went through myriad tests for isolating the lumpy, stinky idle - lights off looking for arcing, pulling injector/spark-plug leads, dialing in the throttle linkage with feeler gauges, etc.
Finally put a fuel pressure gauge on at the cold start valve hoses (not sure how you would tap in on your newer car) and one of the two regulators was flapping in the breeze as to pressure readings. I mean flapping, like 20-40psi six times a second.
Grant told me to try to clean the bad one out. I did, but bought a new one also. Flapping went down to maybe 5 psi swing with old but idle was soooo much smoother and the vicious rich stink was cut 90%. Looking forward to installing the new one.
Would be a bummer if you fixed your cold start issue and carried on with a tired regulator, if the culprit.
Mkii250 (06-18-2014)
#28
I'll just keep updating, in case anyone is interested:
Doug, your hunch was spot on. Bob, I didn't test the pressure but I did replace the fuel pressure regulator. In summary, my car has four problems simultaneously:
1. black smoke is too much gas says Doug, and that's because one of my spark plug leads at the cap was squashed a bit (the brass end) and didn't fit the cap snugly. Also maybe there's something to the theory of filling up with 91 octane and going for a run to blow out the carbon.
2. cutting in and out, I believe now, was caused by low and/or inconsistent fuel pressure. When I say "cutting out", the engine didn't actually stop running but here's what was happening. I'd blip the throttle and revs would immediately drop by 500 then resume and let me accelerate. Replacing the fuel pressure regulator solved this.
3. Cold start injector or valve (CSI) still doesn't work, mine won't arrive for two weeks, so I will continue to have the cold start problem.
4. My fuel pump now regularly wails like a banshee, and in fact needed a thump to get going the other day. I shall install the new one this weekend.
Once the CSI and new fuel filter go in, I will probably discover other problems, not just these four. That's Jaguarship for you.
Thanks everyone for pitching in or following along. This 1986 Sovereign is a happier car thanks to jaguarforums.com
Finale: new cold start injector solved the cold start problem. New spark plug leads solved the missing/rough idle. Probably the old leads contributed to the black smoke issue.
The final remaining "problem" is that the engine still idles at 900-950 hot. The auxilliary air valve is working at least somewhat because it does slow the cold-start high idle after a minute of running. But otherwise, she's running sweet. Thanks to all of you
#30
Asking here because it is the closest subject discussion I found . . . I have an 87 XJ6 6 cylinder that I purchased a few months ago. There are 95K miles on it and it is mostly original. I drive it about weekly for fun and to keep it active. I live in Florida where it is warm and sometimes humid and the car was previously driven in Georgia for a few years.
Often when I start the engine I get black spots and some water out of each tailpipe. The black spots are carbon soot and although not that much, they seem to track on my feet and make a mess. Although these spots are not near my largest challenge with the old Jag, I am venturing into trouble with the lovely lady of the house.
Please send along any suggestions? Many thanks!
#31
I think you have more of an "internal combustion engine" issue than a "Jaguar" issue. The water (liquid) is just the result of the warm exhaust gases passing through the cool exhaust pipe and condensing the water vapor in the exhaust (just like a "moonshine still"). Normal. If you drive for 15+ minutes at road speed, the exhaust will get hot enough that it will no long condense the vapor into a liquid. It will then exit with the exhaust in it's gaseous form.
The soot drops/spots are most often caused by a rich air/fuel mixture or engine burning oil. If the inside of the tail pipe is black and dry/powdery (that's a technical term, in case you didn't recognize it) it is probably rich mixture. If it's black and tacky/tarry (another one of those) it is probably from burning oil.
Take a look at your spark plugs, are they black and sooty or black and oily? I am assuming your S3 has fuel injection, in which case I can't help you with particular trouble shooting, but there are some very experienced owners on this Forum that can.
Dave
Dave
Mkii250 (03-07-2021)
#32
Received 2,399 Likes
#33
#35
the last couple of days my 86 S3 4.2 has been running great and then missing/stalling, replace coil and swapped over distributor and amp thinking it was ignition, thought all was good and went for 100km drive no worries, next day fine and then turned to crap, let it sit for an hour and then ran sweet again to get me home. start up today running like crap with fuel pouring out my exhaust manifold[also exposing a previously un seen crack leaking out fuel when heat shield was removed], front 3 plugs oily and rear 3 sooted up, cleaned plugs and all have a good spark when engine running. Any ideas where to start on the over fuelling?
#36
Received 10,862 Likes
Over fueling in general:
XJ6 Series - EFI Rich Mixture
This pertains to over fueling when cold but is a worthwhile mod on GP:
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
