Throttle Switch Wiring
My wiring harness is missing the connector to the throttle switch that is mounted near the throttle body. There are two wires with bare ends, yellow w/red (maybe pink) and yellow w/ white (yw). The wiring diagram shows these two wires connect to the throttle switch, but I do not know which of the three blades on the switch they connect to. Is the third blade not used on some vehicles? I would like to connect these temporarily until I can find a new wiring harness.
Received 10,920 Likes
Thanks Doug. It is a Ser III XJ6 4.2, USA spec. I can't believe I forgot to put that, bad forum manners, sorry. If that is all the sensor does, then it is easy enough. I thought maybe it did more than that given the size, I guess I am more accustomed to today's mini electronics. By the way, I already found the very useful Captains elec guide.
On my UK version, there was a tiny little switch on the throttle housing that had to be set with the throttle closed. It was for switching off the injectors until revs had dropped to a certain level when one lifted off the throttle. Purpose was to save fuel on the over-run. What happened on US cars I don't know but I would think something similar. Bear in mind the electronics on these cars are all analogue, so it wont be anything complex.
Aus V8S
11-13-2015 11:01 AM
1964Daimler
09-09-2015 11:28 AM
