Thumping sound when accelerating.
could be many things, a muffler or pipe Hanger, a bad U Joint, a bad Transmission Mount,
if the transmission is shifting ok, then it is not the transmission, most likely, it is the transmission Mounts, they are rubber and deteriorate with age, a 1983 is a candidate for replacement transmission mounts. Get new ones on eBay. They are very similar to engine mounts.
It is the transmission mount. This is exactly the symptom of a badly deteriorated mount - when you have it replaced make sure that the mechanic installs it correctly (meaning that he/she has observed how the original was configured).
totalimmortal363
05-05-2014 05:25 PM
canadajag
08-26-2010 06:14 AM
