Tie rod ends of steering rack
My old housemate was a mechanic. He checked the alignment on my old ute by using some chalk to mark the wheel and the ground and rolling the car back and forth.
I conclude there is a way, i dont know it though. check you tube.
A shop will get it perfect though, and for the cost of some front tyres if you get the alignment wrong, thats where i would be going.
Received 2,194 Likes
Received 2,399 Likes
Received 1,442 Likes
+1 . . . and check whether car must be "loaded" before adjusting . . . ie some models set a ground to cross-member distance by chaining down car and adjusting turnbuckles to spec while castor, camber and alignment are done. Perhaps, for front, this may be achieved by driver and front passenger adults in place. Perhaps not, but check Jaguar's specs, especially if new springs/shocks have been fitted.
For quick and fairly accurate setting of toe-in, use an adjustable rod with dog-leg ends to clear under-frames. Depending on in/out spec, first set rod to "just rubbing" inside front centre of tyres, then move and check for "rub" at opposite rear centre of tyres. Easy to set +/- 1mm with this "rod" method, but modern digitals make for greater accuracy . . . and bonus of setting steering wheel to "12 o'clock high".
Cheers,
Ken
Cheers,
Ken
Received 10,989 Likes
Jaguar specifies use of suspension setting links to hold the suspension at xxx-height, commonly referred to as "mid-laden" tools.
Unfortunately not one shop in a thousand will have the tools, if that many. Jag dealers/specialists might.
On all my Jags I have the alignment done at existing ride height and have never suffered any bad consequences. Some shops are a bit pedantic about rules so they won't touch the Jags. Other shops might require a little encouragement to do an alignment without the tools....if they know about them to begin with, that is.
bill70j (06-10-2017)
I use a variation of the string box. I use a piece of 3/4 EMT clamped to jack stands across the front and another accross the rear. Then I run a string between some pre-drilled holes in the EMT.
The EMT was previously clamped together and drilled through both end at the same time to ensure the holes are in exactly the same place on both pieces of EMT
This method works really well. I purchased a digital camber device on ebay.
When I had my tires installed the tire place checked the alignment and it was dead on.
I use a dial caliper instead of a ruler. I like doing it this way becasue the suspension never get unloaded.
Determining Wheel Alignment - String Your Car - Hot Rod Network
DIY Wheel Alignment It?s Easier Than You Think! | Speed Academy
Doug (06-09-2017)
jaguar specifies use of suspension setting links to hold the suspension at xxx-height, commonly referred to as "mid-laden" tools.
On all my jags i have the alignment done at existing ride height and have never suffered any bad consequences. Some shops are a bit pedantic about rules so they won't touch the jags. Other shops might require a little encouragement to do an alignment without the tools....if they know about them to begin with, that is.
dd
dd
