Tie Rod Removal
Old 11-21-2007, 01:58 PM
xb70valkyrie's Avatar
Default Tie Rod Removal
Working on some serious play in the steering on my 1983 XJ6. I need to remove the tir rods on either side. I have taken the nut off the top but I cannot get it to slide off. The manual calls for a special tool JD24. Is there any other way to do it? Thanks.
Old 11-21-2007, 07:44 PM
Jose's Avatar
Received 2,452 Likes on 1,846 Posts
Default RE: Tie Rod Removal
yes, use a tie rod puller and pull them off, they will not come off easily.
Old 11-21-2007, 10:21 PM
dougs02's Avatar
I have had good luck holding a heavy hammer on one side and smacking the snot out of the other side with another hammer. The tie rod bolt has a tapered fit and the blow will usually cause it to loosen. I say usually, not 100% of the time.
Doug
Old 11-23-2007, 11:57 PM
I had to use the tool. It still put up a fight. Thanks guys.
Fred
Jandreu
06-30-2022 03:10 PM
bamforp
09-26-2021 08:04 AM
thedugger1
10-16-2015 10:18 PM
JagBrian
09-21-2015 07:17 PM
JagLove86
09-06-2015 10:36 PM
Quick Reply: Tie Rod Removal
