Time for a new paint job!
Old 03-25-2020 | 07:37 PM
Doug's Avatar
Default Time for a new paint job!
Been a little quiet around here so I thought I'd share my latest project: New Paint ! I'll be adding bits and pieces here and there.
Anyhow......
I've been so happy with the way the V12 conversion worked out that I though I'd go ahead and get the car painted. It really isn't bad at all for a daily driver but at various times in the car's life it has had some panels painted and the color mismatch was starting to bother me. Once seen, you can't UN-see it ! This won't be an expensive paint job but at least it all be the same color.
The following 4 users liked this post by Doug:
anjum (03-30-2020), Flint Ironstag (04-18-2020), Mkii250 (03-26-2020), rustfreemike (03-27-2020)
Popular Reply
04-22-2020, 08:02 PM
Doug's Avatar
Doug
All done. A few snapshots. Later I'll post some decent pics.
It was a real treat driving the car again after so long. My Ford F250, normally used only for actual hauling, is no substitute for a Jag
I think I started this in January but ran into a serious case of "life getting in the way".
Old 03-25-2020 | 07:43 PM
Doug's Avatar
I was very pleased that I don't have to fight a rust problem around the front and rear screens. Previous invoices from years and years ago show a fair sum spent on rust repair and they must've done a good job. There was only a hint of surface rust under the glass. This was easily sanded out and treated with Rust Mort. I cleaned and sanded the entire channel while I was at it and primed with epoxy primer.
A new windshield is waiting to be installed. I wasn't planning on the additional $369 expense but I broke the old one ! Gah !
Old 03-25-2020 | 07:46 PM
Doug's Avatar
A repaint is a good time to freshen and clean all the small stuff. That's where the fun comes in
I found that all the exterior lamps lenses, dull and lifeless from age, really come come to life by using the same products used to restore plastic headlights
Grant Francis (03-26-2020), Greg in France (03-26-2020), Mkii250 (03-26-2020), yachtmanbuttson (03-26-2020)
Old 03-25-2020 | 07:54 PM
Doug's Avatar
The lens gaskets for the tail lights are turning to dust. I found some thin, self-adhesive foam weather striping that makes a decent substitute. I simply cut it into .125" wide strips and it fit into the lamp housings perfectly
Part of the project includes modifying the front side marker lamps to flash with the turn signals. There are various ways to approach this but all of them (that I know of) require the sockets to be un-grounded. I decided to replace the sockets with plastic pieces front NAPA. A Dremel tool was used to cut away the old sockets and enlarge the holes a bit to install the new sockets....which are simply a friction fit.
Here's the socket:
https://www.napaonline.com/en/p/GRO8...iABEgLW8_D_BwE
The little square-ish nubs are easy removed with a utility knife
The following 6 users liked this post by Doug:
Daf11e (03-25-2020), Grant Francis (03-27-2020), Greg in France (03-26-2020), Jag7651 (03-26-2020), LnrB (03-25-2020), yachtmanbuttson (03-26-2020) and 1 others liked this post. (Show less...)
Old 03-25-2020 | 11:31 PM
Daf11e's Avatar
Good stuff Doug.....I’ve been in the process with my series 2 over the past months “prepping”...the current climate will give me heaps of time to finish.
Will be following your knowledge as always!
Old 03-26-2020 | 07:57 AM
iramphal's Avatar
Looks great Doug. Is that Old English White. MyS3 E-type was OEW (not the best colour for an E-type).. It looks great on your car though! Well done.
Old 03-26-2020 | 10:03 AM
Yellow series3's Avatar
Bravo, Doug. Not only will you enjoy your new paint job for years to come, you are an inspiration to us all to turn off the television and get doing something positive. Hagerty had an article about a guy that took advantage of the streets being empty and took photographs of his classic car in front of classic buildings. Another article was encouraging vintage car enthusiasts to clean and tidy up their workbench, tools, and that jar of old nuts and bolts. I am using this time to detail my cars. Lots of YouTube videos on how to do it; I have found places to clean that haven't seen daylight since it went down the assembly line.
Stay safe, stay positive, put on some upbeat music and do something.
Jeff
The following 5 users liked this post by Yellow series3:
Doug (03-26-2020), Grant Francis (03-27-2020), Greg in France (03-26-2020), Jag7651 (03-26-2020), yachtmanbuttson (04-01-2020)
Old 03-26-2020 | 11:21 AM
JagCad's Avatar
Aye, anything but the news!!!!!
Doug:
bavck to OEW or color change?
Wow, jag glass is expensive. My Jeep's new WS was just over two hundred...
Carl
Old 03-26-2020 | 02:34 PM
Fraser Mitchell's Avatar
Doug
Is your car painted with TPA (Thermoplastic Acrylic) ? There can be real problems getting modern-type paint to go on top of it. Jaguar gave up using it at some point after 1982 o 1982, and went over to the normal Clear-over-Base, but I don't know what year.
This article seems to describe it quite well. Not one of British Leyland's best decisions !
Articles
The following 2 users liked this post by Fraser Mitchell:
Grant Francis (03-27-2020), Mkii250 (04-17-2020)
Old 03-26-2020 | 06:57 PM
Doug's Avatar
OEW, yes. Not really may favorite shade of white. I'd prefer something a bit brighter but I'll stick with the original.
Old 03-26-2020 | 07:01 PM
Doug's Avatar
Jeff
Nothing like a good project for some distraction!
Truth is, I started on this in January ago and figured I'd be done by now....but, wouldn't you know it, things suddenly became very busy at work and my spare time became limited. With any luck it'll go into the paint shop next week.
Old 03-26-2020 | 07:04 PM
Doug's Avatar
Doug
Articles
I honestly don't know if mine was originally TPA and, like you, I've forgotten when the change was made. As it stands, I think every part of the car (except perhaps the roof; not sure) has been resprayed at least once over the last 35 years.
Old 03-26-2020 | 07:10 PM
Doug's Avatar
Doug:
Carl
Same color, yes.
The glass was actually less than I expected. I thought it would be $500. The brand is "Pilkington" which is a well known name. I got it from Summit Racing, which is an excellent vendor for all sorts of automotive parts and supplies, beyond their bread-n-butter hot-rod offerings.
A lot depends on volume, I reckon. A new windshield installed on my old Honda Accord was only about $200 including labor.
Old 03-26-2020 | 10:17 PM
yarpos's Avatar
I am surprised Elinor is not here giving you the BLACK talk Doug.
Old 03-27-2020 | 08:12 PM
Steve, I wouldn't even Think of it.
There are BLACK car people, and there are Not BLACK car people.
If Doug was a BLACK car person, he would need no encouragement from me to make it BLACK.
The following 3 users liked this post by LnrB:
Doug (03-27-2020), Grant Francis (03-27-2020), peter J (03-28-2020)
Old 03-27-2020 | 09:19 PM
Doug's Avatar
I'm not
I've had a couple black cars
My hat's off to anyone with the dedication needed to keep 'em lookin' really good. It ain't me
LnrB (03-28-2020)
Old 03-28-2020 | 08:41 AM
Mkii250's Avatar
86s were TPA, 87s were clear over base.
Doug (03-28-2020)
Old 03-28-2020 | 12:20 PM
JagCad's Avatar
I've always believed that my 83 was painted in TPA! it has performed quite well. No cracks and crazing. Still quite shiny. Only a patch or two on the bonnett are duller than the other parts of the car, including the roof!!
Black cars are striking. My son has a 64 Chrysler "K" car in deep black. he swapped an engine job to a pal that was a body and paint guy. It invites attention when driven. the only car in the fleet that enjoys a garage...
My Jaguar enjoys a garage, the Jeep does not Alas, the Jeep is showing peeled clear...
Carl
Carl .
Old 03-30-2020 | 08:49 PM
Doug's Avatar
I stand corrected. It's actually "Tudor White" (code NDC)
In any case, it isn't a bright white. It's slightly creamy.
Old 03-31-2020 | 01:05 PM
JagCad's Avatar
Process it, when mature with Dr. Gregory's formula. high carnauba content wax!!
It will be bright !!!!
Carl
Doug (04-03-2020)
Quick Reply: Time for a new paint job!
