Tranmission shifter
Sounds like the neutral safety/reverse light switch needs adjusting. On your car it'll be on the side of the transmission.
Here's a write up on adjusting the switch to make the reverse lights operate. The same basic method is used to adjust the switch for proper starting
Adjusting Backup Lamp Switch, Series III XJ6
Some switches were not capable of being rotated. In that case the switch must be removed and the screw hole lengthened to allow the switch to pivot
Mad Matt (05-17-2015)
n2audio
17
10-09-2015 10:53 PM
