Transmission fluid
Received 10,988 Likes
The original specification was Type "G" but that's been obsolete for ages, being replaced by Type "F" or Type "FA".
If you want a slighty softer shift ....might not be a good thing on an old trans.....use Dexron III. Otherwise use the F or FA.
Not sure about the noise. Hvae a good look at the transmission mounts though.
86JAGVP (04-28-2012)
LOL! Love it! I learn something new every day.
So I checked my transmission fluid. It was 1/2 qt low. I sometimes have smokey exhaust, and the transmission is a little jerky on upshift or downshift. The Haynes manual talks about a ruptured Vacuum control unit diaphram being the cause of these symptoms. Would anyone know where this unit is located and whats involved in repairing this??
86JAGVP (05-04-2012)
Thanks Doug!
Your right! The Haynes manual is really confusing and often misleading. I appreciate your insight and experience.
The smoke is just normal grey smoke, and only for a second when the engine is first started. I changed the plugs last weekend and they all looked perfect with just a little tan coating on each.
I added transmission fluid. It was 1/2 qt low. I have not heard that noise since adding fluid.
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
chatmanx
09-11-2015 07:17 PM
