Transmission Fluid Question
I blew out my 1967 Jaguar 420 engine (the car has a manual transmission) and then had a 4.2L XJ6 engine put in. My transmission is starting to slip and when I put the car in overdrive it jerks. Is there a transmission dipstick somewhere on the XJ6 engine. What type of transmission fluid should I use? Thanks! Jordan
Received 6,327 Likes
Hi Jordan, Welcome to the forum. It depends on the age of the transmission and what model it is.
I have a 1973 XJ6 with BW12 transmission. It has a dipstick located just behind the engine oil dipstick.
Originally mine took Type A fluid,which is no longer available but Type F is the replacement. I think after 1977 they used something different again(maybe Dextron II)
Add a photo of your engine/tranmission if you can it might help identify your trans.
I'm sure members with much more experience will be along to add their help shortly.
Visit the new member area and post an introduction thread(link below)
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
![Transmission Fluid Question-dsc_9382.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/86211d1480972775t-transmission-fluid-question-dsc_9382.jpg)
![Transmission Fluid Question-dsc_9383.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/86212d1480972775t-transmission-fluid-question-dsc_9383.jpg)
![Transmission Fluid Question-dsc_9385.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/86213d1480972775t-transmission-fluid-question-dsc_9385.jpg)
The "dipstick" is on the front left if you are standing in front of the car and facing back. The cap says Automatic Transmission Fluid. Thinking this out...it was the engine that was switched, not the manual transmission. I searched on-line and could not find the type of transmission used in a Belgian 1967 4 speed manual with overdrive Jaguar 420. Anyone know the type of transmission & appropriate fluid? By the way I could only find a long oil dipstick on the back right of the engine (facing back to the car again). Thanks! Jordan
o1xjr is correct, what is shown in the picture is the Power Steering Fluid Dipstick, NOT the transmission fluid dipstick.
what you are reading on the cap is the type of fluid you can use in the Power Steering Pump, since automatic transmission fluid can be used in a power steering pump/system.
moreover: Manual transmissions do not use "FLUID", they use a specific grade of ENGINE OIL. (maybe 10 or 20 weight oil).
The reason you can't find a transmission dipstick is because you have a Manual Transmission.
if your transmission is slipping, chances are your CLUTCH is the problem, not the transmission oil.
you need to take the car to a Jaguar mechanic who can properly diagnose the problem you are having.
Agreed.
The manual transmissions use a "graded oil" as said, and usually a SAE80 or 90 in that era of transmission.
The oil spec charts I have access to state "SAE80 Smooth Shift".
Manual transmissions CANNOT slip, so any slippage you are experiencing is purely related to the clutch.
Clutch replacement is the only real way of fixing the slipping.
Firstly, clutch slippage is purely a female event. It cannot decide to "drive" or "not drive" the transmission.
The jerking is possibly oil contamination on the clutch facings (which, like brake pads, must be oil free). The only fix here is replaement. Obviously OLD AGE plays a huge part also.
Power steer fluid is simply ATF (Automatic Transmission Fluid), and should be drained and refilled with fresh annually.
Attitude928 (06-01-2014)
Note that the power steering pump in your picture is a GM (General Motors) 'Saginaw' pump used in Jaguars starting with the model 420 of 1967 all the way to the Series 3 XJ V12 model made until 1992.
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
