Transmission leak
Transmission leak
Hi everyone I have a very slight drip from what i am guessing to be the transmission oil pan. I have a new gasket so I figure I will start there. Do you refill through the yellow dipstick port? Should I use a specific transmission fluid?
thx in advance.
1979 jaguar xj6L series
thx in advance.
Received 10,968 Likes
Jag7651 (09-16-2017)
Transmission
thx in advance.
thx in advance.
out with finger, then tighten up very lightly.
Let dry over night before filling.
Put 4 quarts in through the filler tube and check the fluid when warm,
do not put more then shows 1/4" on the stick or it will leak out.
Walter
Received 2,399 Likes
A tip that might help.
Some folks think tighter is better on fastening tin to iron or alloy. Not so.
And it deforms the metal around the holes for the fasteners.
1. Result: Less effective clamping, voila leaks !
2. Fix. Use a small hammer and a backer. Tamp down the ridge around the hole ands restore a uniformly flat surface.
As a general practice, I apply a sealer only tot he part that comes off. And mostly for keeping a good quality gasket in place during the install.
Carl
Carl
Grant Francis (09-18-2017)
Will this work
QUOTE=Doug;1760777]Yes, refill via the dipstick tube
You [should] have a Borg Warner transmission. It's widely accepted that Type F of Type FA is the most appropriate fluid. The original specification was Type G as I recall....but that spec was made obsolete decades ago.
DD[/QUOTE]
DD[/QUOTE]
Received 9,423 Likes
level 1 (09-20-2017)
