Transmission tunnel rot
After finally getting the center console out and removing the carpets, pads, old coins and buttons I got to the real ugliness. I knew the floorboards would be bad and thought it might creep up into the toe boards and transmission tunnel but it looks worse than i had hoped. I have new floorboards and can source the toe lick panel but cannot seem to find anyone who deals in the transmission tunnel. Any help here would be totally appreciated. I think this also solves my dilemma on whether to pull the engine and tranny! In for a penny, in for a pound!! Hopefully will uncover the passenger damage today.
Mkii250 (01-04-2022)
Received 9,208 Likes
Received 2,399 Likes
The following 2 users liked this post by JagCad:
davidboger (02-17-2022),
The following 6 users liked this post by Jose:
Daf11e (01-03-2022),
Jag7651 (01-02-2022),
lickahotskillet (01-04-2022),
LnrB (01-02-2022),
LT1 jaguar (01-02-2022),
and 1 others liked this post.
Western cars don't rot like that. California, Arizona climate preserves cars.
Sorry to say this but like Jose said it looks like a $$$ nightmare. You would almost have to make a new bottom half for the car. It looks like someone already used fiberglass to cover the rust which just made it get even worse. You have to cut back the rot until you get to solid un-rusted steel, and I'm willing to bet the more you uncover the more rust you'll find. I've only be working on / looking for Series 3 but I'm sure you can find a better Series 1 to start with with. What's still good on this car, interior, engine, etc ? Find a solid body and transfer your good parts to it. I have not done much welding but did do all the measuring, planning and cutting to replace pans on a early corvette which is similar, you have to have good structure to weld to get acceptable results.
Good luck, I'll keep a look out in my area for a better 1
Cheers,
Brian
Cheers,
Brian
My series 1 was as rotten as yours, at least in this area. In fact, the complete driver footwell was about gone.
For me, I don't really care if it's 'original' so any piece of sheet metal will do to fix this. In fact, my footwell is made of what once was a series 3 xj6 door as that was what I had at the time.
It's a bit hard to see on this picutere, but see for yourself how much was gone:
Anyways, I would suggest: get a piece of sheet metal and get welding!
Wilfred, I love your enthusiasm! I will probably continue the dismantle and see just how extensive it is. If it is truly terminal than the rebuilt engine and transmission need to come out anyways which will give me great access to repair if I go that route. I am leaning toward tackling it!
Thank you Larry, I have the floor pans and see that SNG has the toe kicks. It appears the series 1 has the weird step at the bottom/sides of the tunnel while the later series go to flat flanges. David Boger has a series 3 tunnel that I might have to do like you suggest and just fabricate the bends at the bottom. Trying to piece it together!
wydopnthrtl
06-03-2019 12:38 PM
