Trip computer dark
Took my '84 XJ6 for a new hazard switch and (thanks to this group) got what looked to be a good one. 24 hours later, my turn signals stopped working (but hazards were fine), so I took it back to the shop which replaced the flasher unit but not before the turn signals miraculously self-healed and started working again.
Now I've got working signals and hazards but my trip computer is dark, no functionality. My wife noticed a brief flicker of life when I turn the key in the ignition but nothing else.
Any input on what to test for or likely suspects?
Thanks in advance,
Rhett
Thanks in advance,
Rhett
Hi Rhett,
Display flickered... suggests loose wiring / earth.
There is a fuse under the dash for the trip computer which may have blown, in which case, why did it spike??
This sounds silly, but did someone push the 'Disp.' button two from the right on the trip computer? That kills the display until you push it again, just like being out of phase in a teleporter...
Hope this helps,
Cheers,
Nigel
Hope this helps,
Cheers,
Nigel
Rhett (11-15-2015)
Received 10,906 Likes
Hi Rhett,
Hope this helps,
Cheers,
Nigel
Hope this helps,
Cheers,
Nigel
Received 2,399 Likes
Rhett (11-15-2015)
Add ideas:
1. The fuse has gone intermittent. Looks good, but flawed inside the glass.
2. Fuse holder contacts have lost their grip. Clean them, or merely roll the fuse in place.
3. Check the S57 Jaguar electric schematics Check for power.
4. Ignition switch feeds????
Carl
Carl
I feel like an idiot bothering you all with this but it honestly didn't occur to me that it might actually be an easy fix.
Thanks everyone!
Received 3,960 Likes
Rhett (11-15-2015)
Received 6,327 Likes
I have been down that track before and learnt from it, always good to ask the questions you may think are silly. You don't know what you don't know and the only way to find out ask.
Now, go 'round and clean *all* your fuse clips and the metal end caps on the fuses. And, whenever you're working on the car and come across a ground point, take 5 minutes to remove the wires, clean everything up, and refasten. With these two things you'll pre-emptively eradicate most of the much-ballyhooed Lucas horrors
The following 3 users liked this post by Doug:
I'm not sure whether it was the unplugging and reconnecting the 2 connectors a few times, or twiddling the fuse that fixed it, but it took just seconds and I'm happy! Thanks Doug.
Dale Konkol
10-25-2015 11:12 AM
Marty Jackson
10-16-2015 03:21 PM
