trip computer/fan
trip computer/fan
can i get some help on this??
i unplugged trip computer to check if my spare worked. since reconnecting it, it resets every time i turn car off (have to re set clock)
as far as the fan goes...the fan in front of my radiator does not spin when engine is running..is this a problem?
my temp gage usually is either in the green at or a little past the 90 marker
Thinking back here, scary I know.
The trip computer resetting is "possibly" the inline fuse located (memory again) up on top of the unit. I say this due the fact that it sounds like it is losing it voltage that retains memory, just like a car stereo.
The fan in front is I think, and a/c auxillary fan, and a thermo overheat assist fan, so at the temps you mention it should not be working.
Others that are WAY more familiar with S3's will sort this I am sure.
doghead08 (08-04-2011)
Received 10,990 Likes
