Troubleshooting suggestions (?) for new owner with pics
I need a sanity check. This is for a US 74 xj6. I pulled the fuse panel under the dash and saw there were 10 amp, 25 amp, and 35 amp fuses. When I Googled the stock Lucas fuses a post popped up on here with British to American cross references (Lucas to AGC). HOWEVER, I forgot that the person making this post may have actually been in Europe. Anyways, I ended up ordering Bussman AGC fuses in 7.5, 15, and 25 amp. Should I have actually ordered the Bussman AGC in the 10, 25, and 35 as the amps were displayed on the fuse panel?
I woke up this morning and it was literally the first thing that popped into my head. The joys of being an automotive enthusiast!
Thanks but my question is really if the fuse markings on the fuse panel are British or American...
I.e. the Bussman conversion. Chart is:
English Type. = American Standard replacement.
50 amp. = AGC 30 or 25.
35 amp. = AGC 25 or 20.
30 amp. = AGC 20 or 15.
25 amp. = AGC 15.
20 amp. = AGC 10.
10 amp. = AGC 7.5 or 5.
5 amp. = AGC 3.
So on my fuse panel, it says 10, 25, 35. Are those British or AGC values? I assumed british, so I bought AGC equivalents. I'm not sure if I'm right.
25 amp. = AGC 15.
20 amp. = AGC 10.
5 amp. = AGC 3.
Received 10,989 Likes
Chip C (04-14-2017)
copied from the Bussman Conversion Chart:
English Type American Standard Replacement
50 amp AGC 30
35 amp AGC 25
30 amp AGC 20
25 amp AGC 15
20 amp AGC 10
10 amp AGC 7 1/2
5 amp AGC 3
Personally, I feel even this chart results in fuses rather larger than needed, so for example I use an AGC 20 to replace the original "35 amp" fuse in my TR3A. My conversion chart would go more like :
Randall's Recommendations
50 amp AGC 25
35 amp AGC 20
30 amp AGC 15
25 amp AGC 15
20 amp AGC 10
10 amp AGC 5
5 amp AGC 3
50 amp AGC 30
35 amp AGC 25
30 amp AGC 20
25 amp AGC 15
20 amp AGC 10
10 amp AGC 7 1/2
5 amp AGC 3
50 amp AGC 25
35 amp AGC 20
30 amp AGC 15
25 amp AGC 15
20 amp AGC 10
10 amp AGC 5
5 amp AGC 3
Searching forums turns up so many results, I'm not sure what is correct....I had ordered a full filter. It looked like there is an in line unit beneath the carbs. The FRAM one I got, G7404, looks much larger. Other places show there is a filter in the trunk and/or under the car along the frame, and one that is in each carb. Can someone clear up where the filters are for a 74. Suggested part numbers?
And where is the water temp sensor?
#30
Received 9,472 Likes
I personally like fuel filters out where I can easily change them, not back with in-tank pumps or under the car. Just before the carb(s) is where I would move them (assuming there's space) no matter where they were originally mounted. I also like the biggest diameter filter cartridge I can find, not one of those 1/2 inch jobbies made for the likes of my lawn mower.
But that's just me.
But that's just me.
#31
#32
First, remove the tail lights and then read this thread:
https://www.jaguarforums.com/forum/x...-166388/page2/
It's not hard, but the senders are mounted very low in the back of the tanks. You could jack up the rear if fuel level is close but not quite empty.
#33
#34
I think there is (or should be), only 1 fuel filter in the XJ, carbed or injected, the one in the trunk / boot.
http://www.sngbarratt.com/CatalogueP...=13903&a=17403
the one near the Carbs is probably one that was added by a previous owner, especially if it looks "auto-partish".
level 1 (04-21-2017)
#35
#36
#37
#38
