turn signal relay
my right indicator in the speedo never fails, but the left indicator in the tachometer blinks once or twice and stops blinking.
I believe it is the column switch, i have 4 or 5 flasher relays and it happens with all.
also I have replaced the diode in the tachometer harness, a waste of time. Still does it.
Don't know if it affects the bulb out function, installing LED bulbs makes that indicator come on so I just removed the bulb from it.
I assume you can do just one side. You get to them by removing the tech and Speedo so go ahead and try one side. You might want to mark which way it is installed so you can put it back if you don't like it. You can't tell by looking at the diode which way is up (it's covered in gooey tape) but they are definitely directional.
everything else works normally.
Saemetric
12-05-2014 05:56 PM
saustin1974
02-14-2011 09:39 PM
