Turning Engine Over
HAHAHAH, special Jag tool,YEP, you, a socket, lots of swear words.
You will need alcohol of course, for YOU, not the engine.
Find a socket to fit that hex nut thingy on the bottom pulley, which is the front end of the crankshaft, and then a breaker bar to fit the socket, and rotate CLOCKWISE ONLY as view looking at the FRONT of the engine.
Unless its going to sit for years, dont bother too much. I went to the MK X yesterday, and its been 3 years, and fresh fuel, intravenously fed to the 3 carbies, charged battery, turned the key, pushed the button, and away it went, FAITH, ya gotta have FAITH.
I removed the sparkers, and reapplied oil to each cylinder, and went home.
adenshillito (01-04-2019)
The following 2 users liked this post by David84XJ6:
adenshillito (01-04-2019),
Coventrywood (01-05-2019)
adenshillito (01-05-2019)
The following 2 users liked this post by Saemetric:
Grant Francis (01-06-2019),
o1xjr (01-07-2019)
jkm210
XJ40 ( XJ81 )
01-31-2017 06:21 PM
jkm210
01-25-2017 07:13 PM
lexyb
09-25-2013 11:32 AM
briscoeq
12-27-2012 02:04 PM
