V12; remove manifold/downpipe sealing ring
Received 10,989 Likes
I often use a propane torch in conjunction with [whatever brand] rust-breaker spray product. The heat always seems to help the penetrating oil work.
You could also use a small cutting tool (like a Dremel) to slice thru the rings, or a chisel
However.....
Those rings slide over a sleeve which is not very well anchored into the manifold and not very robust....so some caution is needed
However.....
Rogelio Serrano
11-25-2016 07:10 PM
