V12 header sources
Old 07-12-2022, 07:54 PM
garethashenden's Avatar
PMed
Old 07-12-2022, 08:46 PM
lickahotskillet's Avatar
Driven Man is now part of American Powertrain. At the time I talked to American Powertrain last year, one guy was assigned to the Tremec kits for Jags. I have purchased from American Powertrain in the past. They were always helpful to me.
Old 07-12-2022, 09:42 PM
Howsurcargo?'s Avatar
Good to know! But I just looked them up and they do not list a kit for a Jag V12. Should I ask them if they have such a kit that they do not advertise?
Old 07-12-2022, 10:49 PM
Certainly worth the call to
Driven.
There is thejagguru on e-bay the makes three pedal set ups. You can put your year and model in for fit.
Old 04-01-2023, 07:26 AM
Mguar's Avatar
Originally Posted by Howsurcargo?
Hi,
I have a 1975 XJ12C V12. I have been a motorhead for 42 years but I am new to Jag ownership. I believe that it is a good thing to improve airflow through an engine and a good set of headers generally helps if everything is set up correctly. I have been told that the stock V12 exhaust manifolds work pretty well and that headers are not worth the effort. But I am still looking around at my options. So far I have found a company in England and Australia that offer V12 headers. The Australian ones are more expensive but look to be a far better design imo. Are there any other sources to a quality made exhaust header for a V12 for my chassis that anyone can direct me to? Second question, how do I get the Australian piece to the US if I d not find any good alternatives? I have no knowledge about what the shipping options are. I checked with Fed Ex and it was a $6,300 bill. Obviously I am not doing that. DHL came in at something like $2300 but that is still pretty expensive. If I remember right shipping from England was less than $100 so I am hoping there are other options and I'd like to avoid any CA ports if possible.
TYIA
Chris
Roger Bywater is right. The stock cast iron manifolds are very good indeed. If you build a proper set of equal length headers you will fill the engine compartment with tubing, and prevent air from flowing past the engine and getting out.
That means overheating. The radiator works by air flowing through the radiator, picking off heat and on out below the engine. If that exit is blocked off by tubing that will reach up to 1200 degree f You’ll have heating problems.
Second additional power, you will gain at most 4% more. The stock manifolds are very good indeed, plus they only weigh 4 pounds each. ( total 16 pounds).
If you want improvements polish the raw cast iron up and have them thermal coated. Silver is traditional but they also have black and red. That not only gains you a slight power increase but retains the heat to exit out the tail pipe rather than in the engine compartment.
warrjon
03-19-2023 07:42 PM
paulyling
09-25-2022 11:54 PM
jww427
E type ( XK-E )
20
01-23-2020 03:59 PM
MarcusJames
09-03-2019 05:07 PM
velder
07-06-2011 01:28 PM
Quick Reply: V12 header sources
