v12 vanden plas wont start until i vent gas cap
Received 10,916 Likes
Behind the right front wheel, attached to the inner part of the wheel well, you'll see a couple pipes.
One one of them...the one that runs horizontally...you should see a small plastic valve. This is the vent valve for the tanks. Disconnect the valve on the aft side; that is, if your looking in the wheelwell and see the valve on the horizontal pipe, you want to disconnect it from the pipe on the left side, so that the end of the pipe is open to atmosphere.
Assuming no clogs in the pipe your tanks are now vented to the outside world at all times.
Post back if anything changes.
Charlene n John
09-28-2015 06:01 AM
