vacuum hoses on a 4.2
Me again
Firstly, I've just found out that the hose from the distributor isn't connected to anywhere and I don't know where.
Something else I don't know is the name of the thing that pokes out of the heat shield for the exhaust manifold. Nor do I know where it's little black hose is supposed to end up.
And underneath that, on the firewall, is a place where 2 lovely hoses emerge. One of them is slightly larger and comes out underneath the other. It happily goes to a 3 way connector on the other side of the car and all seems in order there, but the other one just hangs around looking silly with it's joined to in thing end.
I'd really appreciate your advice, so as all these little hoses suck and blow to their hearts content. Just the right way would undoubtedly be nice.
Thank you all kindly
Received 2,399 Likes
I can help a little bit. Down under the battery, LHD car, are the hard to reach and attach from above. These are in and out for the Dellanair climate control system. One comes from the vacuum reserve tank by the brake booster, LHD cars.
On another forum, J-L, tw or three of us colaborated and posted diagrams for the hoses.
If your car is a V12, the hose is a vent for the distributor. if an I6, vacuum advance or retard.
Remove the heat shield and look to see where the other end goes. And EGR control. Some cars got EGR, others not.
Carl
Carl
Carl,
Thanks for that. But do you still have the diagrams or could you let me know where to start looking?
Mine is rhd with the battery on the left. And a v6.
I'd quite like to connect these 3 loose ends, especially the one for the distributor, so I can find the next thing to sort out. Luckily the previous owners didn't like to add new wiring, that's a nightmare.
Received 10,989 Likes
geneo (03-28-2017)
Doug,
Please consume a beverage of your choice because I'm raising a beer to you for that.
Spent ages looking for a part that ain't there, so I connected the distributor to the, I hope, carb port.
The egr now goes to it's heat sensor on the water rail and the cruise control might actually work now because someone else had put the egr onto the heater valve.
Fingers crossed it doesn't play up.
Having played with vehicles most of my life, I'm absolutely loving the sheer amount of data available. One of my Toyota's for example usesuses almost 14 metres of tube for its vacuum system and no one at Toyota thought to actually produce a diagram!
Cheers mate.
Cheers mate.
