valve adjustment
I am very surprised you've got to that mileage without a top-end overhaul, frankly. Good advice on compression test. Valve adjustment can be a bit of a PITA if you cannot get the right thickness shims. A neat trick is to turn them over, so the little dent the valve eventually makes in the shim is on the other side and the valve bears on a fresh surface. You will definitely need a micrometer if reusing shims, because the thickness letter code wears off.
Received 10,989 Likes
Well, it might be a good time to check the adjustment, at least. Checking the valve clearance is easy. *Adjusting* the valve clearance is a royal pain in the butt.
Agreed on the compression test.
Do both and decide from there.
Marka
22
09-11-2016 12:09 AM
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
