Valve Adjustment Frequency
Received 10,979 Likes
They are seldom adjusted.
Not sure if this is because the clearances are seldom checked, or because adjustment is seldom needed, or because the actual job of adjusting them is a royal PITA.
*Checking the clearances* is easy, though, so you could do so to satisfy your curiosity if nothing else.
Received 2,399 Likes
No experience with the valves on this engine. But, some in other
non hydraulic lifter engines. It is a metal to metal thing. Most, if not all engines in this design live out their useful lives sans valve lash adjustment.
Caveat; That is assuming no abuse.
Very early engines had no means of setting lash other than removing metal. Good for the life of the engine. But, in that era, 100,000 miles was a minor miracle.
The only "weak spot", if indeed it is that I might consider is the "shim" method to set the initial "lash". Are they as long lived as
lifter material, cam lobes, and valve stems??? I don't know.
Carl
Carl
Yeah, I've never seen valve adjustment on any of the 'routine service interval' charts.
Interestingly, re-torqueing the head bolts is recommended every 12000 miles....except for North American market cars where that recommendation is absent, along with a few others !
As to us:
1. Lower compression in USA bound cars? I dunno, if so, keeping the squeeze on not so problematical.
2. they figured that most of us ain't gonna do it anyway...
3. The guys/gals that lease/buy a new Jaguar are not going to keep it over a couple of years...
4. No 100,000 mile warranty to concern Jaguar. I don't know.
Carl
Carl
Received 2,266 Likes
JimC64
12-29-2015 06:41 PM
