VDP telescoping stopped
Guest
Posts: n/a
96 XJ6 VDP.
The telescoping of the steering column suddenly stopped. When inserting (or removing) the key, the motor runs, and you can hear the gears, but there's no motion of the column. It does move up and down fine.
It sounds (to me) as though a gear is out of place and they're, therefore, missing each other?
Any suggestions on how to resolve ... I can drive it with the column that close to the dash, but wife can't ... and it's her car, LOL
More than likely the reach motor assembly went south. You can download the JTIS application and it will give you an idea of what to replace. Even though it covers the 1998-2003 XJs you should be able to use it in this case. You should be able to access the reach motor assembly by moving the steering wheel column all the way down and removing the column covers and the knee bolsters. You may want to try the various Jag salvage sites for the part.
Mike
Mike
Received 10,975 Likes
aholbro1
08-05-2021 05:02 AM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
