VIN # Question
I was looking for some parts online and noticed that the VIN number on my jaguar is indicated the model as "VANDEN PLAS". SAJ "K". The vehicle is marked with "SOVEREIGN" and there is no indication of it being a "VANDEN PLAS". Could this have been an error? They have different parts for these two models.
Received 10,905 Likes
That's the North American VIN, assigned by Jaguar to meet North American convention. Whatever source you're using to decode it might not be able to digest it. Try the VIN that's stamped onto the flat ledge at the top of the cowl panel....right about where the two fender braces comes together. That's the number the car was "born with", so to speak.
I tried it on a couple decoder pages and it isn't panning out. It shows as a 1990 Canadian market VDP...which would be a Ser III car, have a V12 engine...and would have a last six of something like "480xxx" or thereabouts
We need to find a decoder that works on non-North American VINs
The VIN on the cowl plate is SAJJKLLD4LJ618405. I'm still trying to find the right decoder.
Looks like both apply. This car is a 1990 XJ40 4.0L. The base car is a Sovereign, but the Vanden Plas is a higher trim level, a little upscale compared to the Sovereign.
Cheers,
I presume that's from the Jaguar data base? Very good :-)
The description "VDP 4.0 Sov 1990" is contradictory, though.
For the Canadian market a 1990 "VDP" would be a Ser III V12 but a "Sovereign" would be the XJ40 car, as mentioned.
I guess even Jaguar had problems getting the database correct for all years/models/markets :-)
Cheers,
This is an 1990 Jaguar XJ6 4.0L Sovereign. (Early 1990 series). I found one decoder which decoded the original VIN as coming from a Sovereign. The confusion was with the NA VIN decoding as a Vanden Plas. This car does have the higher trim level and accessories listed as standard on the Vanden Plas.
Well, I think there's no way around some of these glitches. Whoever sets up these decoder sites gets the data from....somewhere....and can't possibly verify its accuracy for all manufacturers, all markets, etc.
The Jaguar model line-ups (and many others, no doubt) can be very confusing because of market-to-market variations and model name usage. If I'm correct that the info from XJRGuy came from Jaguar's own database it proves how complex it can be, as Jaguar itself decodes the VIN as both a VDP and a Sovereign :-).
One example, albeit one involving a very small number of cars, would be the last of the Canadian V12 Ser IIIs. These last 100 cars were built as Daimler VDPs and the VINs decode as Daimler...but the cars are badged "Jaguar VDP".
Cheers,
Ipc838
09-13-2015 03:27 PM
