Viper malfunction
Old 04-03-2016, 08:21 PM
GuBe's Avatar
Default Viper malfunction
XJ6,ser 1 -72. Viper moves only on normal speed, not at fast speed, and does not stop at end point. Wiring seem ok according to my my car electrician. Can there be something wrong with the motor? Have tried 3 different swiches.
Old 04-03-2016, 10:57 PM
Renocat's Avatar
I believe it's a two speed motor with a park switch. Likely You can take the motor apart and look at the brushes, they're probably worn out.You may be able to get a repair kit, but likely be a better option to replace the wiper motor.
Old 04-04-2016, 07:03 AM
GuBe's Avatar
It's a two speed motor with park. If brushes are worn - should it then work at all? It works fine on normal speed.
Old 04-04-2016, 09:15 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Good thing, a functioning "Viper" can be dangerous. LOL!!!
Apologies, couldn't resist, I am the king of typo's!!!'
check the archives here, I recall a nice write up with pictures to
include the brush replacement.
But, yeah, bum brushes should mean no speed at all.
Carl
NathanDD6 (04-05-2016)
Old 04-05-2016, 11:10 AM
GuBe's Avatar
Now I have motor running on both normal and high speed, but high speed is working RHD and normal speed is working LHD, and still no park. Interesting. Motor then seems OK. Malfunctioning must be inte wireing. Live in Sweden with a LHD.
Old 04-05-2016, 04:42 PM
JagCad's Avatar
GuBe:
Tis just one of those things that make ownership of these cats "different".
A learned Gentleman on an other forum posted on it. It take learning a deft flick at just the right time of the stalk to park the blades at the proper rest position. I manage it at times. Don't drive it in the rain often.
Carl
Old 04-06-2016, 06:23 AM
GuBe's Avatar
Still talking about ser1 XJ6. Seems that the two speeds work only when connected directly to the battery, and not connected over the switch.
BUT if you disconnect the 5 connector socket from the viper motor you see a plastic tip on the socket underside that can flex inwards, and beneath the socket and the case there is a thin plate with one round hole where the mentioned tip passes trough + another smaller square hole. WHAT IS THE FUNCTION OF THE PLASTIC TIP AND THE PLATE? I can't see the function or how it work. Could take a pic but dont know how to post it here.
Old 04-06-2016, 08:33 AM
JagCad's Avatar
Don't have the answer to the function question.
But, if you use the "go advanced" box to post, a lot of "fancy" stuff is available, including a link for "images". I managed to post there with an image or two.
But, I usually stick tot he basics. This machine doesn't respond well to image posting. A Win 1 issue?
Another on tried and true XP does it just fine.
Carl
Old 04-06-2016, 09:09 AM
GuBe's Avatar
Carl
Sorry Carl, I don't follow your slick talk. Reminding you Swedish is my natal laguage
Old 04-06-2016, 10:27 AM
JagCad's Avatar
Better than my Swede.... Non exisatant!! Volvo, about it.
When you hit "Quick reply", look above the box to type in. Several
icons. Count 7 from the left. It is a box simulating an envelope for the
post aka mail!
Click it. It will open a window for browsing places to select pictures from. Just follow it and it works.
I'll try here. Reverse lamp schematic???
Carl
Old 04-06-2016, 10:28 AM
JagCad's Avatar
It did not do it????
Apologies.
Carl
Old 04-06-2016, 12:11 PM
GuBe's Avatar
Default I'll try
Apologies.
Carl
Socket mounted<br/>
Socket dismounted
template in place see where the ponter fits in hole<br/>
Template isolated<br/>
The Vehichle
Old 04-06-2016, 01:30 PM
JagCad's Avatar
Yahoo! You got it. I not!
Now, someone that understands the function here can help you better than I!
Carl
vsol
03-24-2016 07:37 AM
yellowser22+2
E type ( XK-E )
03-23-2016 01:06 PM
Ron Ho
03-21-2016 04:18 AM
XJsc-guy
03-21-2016 12:51 AM
KenXJ
03-20-2016 10:17 AM
Quick Reply: Viper malfunction
