Warped Underscuttle
Warped Underscuttle
Things are moving along nicely on the interior and I'm finding that some of the dash parts are not as straight as they might have been when the PO took it apart 15 years ago. Picture of passenger underscuttle that is no longer flat, leaving room for lots of daylight around the fuse panel door. I am usually pretty tolerant of something like this, but if there is a way to straighten it, I would do it.
Dave
Dave
mine is like that too. The components behind it cause it to warp. I gave up trying to straighten it. Once the foam takes a set, it becomes permanent.
just make sure the top edge excess material goes under the trim, between the wood and the crash roll. The way it is in the picture looks too low.
Received 10,944 Likes
I fixed a couple of these bowed panels, many years ago.
Get a steel rod from the hardware store. Threaded rod will work. Place the rod over the bowed section. Use your favorite epoxy to glue the ends of the rod in place. You now have a rigid 'spine' of sorts.
The idea is to pull the bowed section up to the rod and secure it. I recall using some black utility wire through the face of the panel and tying if off to the rod. It was nearly invisible, and a great improvement in appearance. But, you could devise any number of methods.
I'm sure you have noticed there is a bracket leg welded to the blower fan case that fits into a cavity at the bottom right corner of the trim panel, right? Same on the left trim panel.
it holds the bottom of the panel from hanging loose. Insert the leg into the trim panel before anything else.
Received 2,399 Likes
Mine was OK when dropped to replace the ignition switch.
I did sub in Allen head sxrews for the slot screws. I have a dislike for slot screws!!
In this case a ;lenmgyh of oxy acetylene weldig wire looks about right.
Still quarantined. smoke as well a reason. it seems better. i have the front dorr open and a fan to xhayst the house..
Carl
Carl
LT1 jaguar (08-26-2020)
The Coupe
06-24-2014 06:53 PM
