Water Leak
I am purchasing a 1970 Xj6 in a couple of weeks. According to the owner the water pump is leaking. I am not sure whether it is just the gasket that seals the pump to the block, or whether the pump is actually leaking.
What is the common failure mode of the water pump? Is it usually just the gasket that fails, or should I be expecting to fit a replacement pump?
The previous owner has done a general service on the car (fluids, plugs, wires, timing). I plan on replacing the thermostat, all of the water hoses and the belts while I am doing this job. Are there any other items I should check/replace while I am at it?
Chris
Chris
Received 10,910 Likes
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
mikimogo
09-22-2015 08:09 PM
mikimogo
09-14-2015 08:34 PM
