water pump question.
The water pump on my 85 series 3 was leaking quite a bit recently but started leaking profusely after i tightened the power steering pump tensioner which is fed from same belt. I have removed the pump and cant see anything obviously wrong. Should i try new gaskets first and refit or can i check the pump to see is it gone then order a new one? Cheers jj.
Yeah.
When the bushings go, the shaft wobbles and the seal is done for. in olden days, a light emulsified oil was used when antifreeze was not necessary. The lubricated seals and bushings and life was extended. Now modern antifreeze does have a lube and all is well as long as the coolant is fresh. But, nothing is forever, coolant, seals or bushings. Therefore, as Grant says, it is ver. Get a reconditioned pump from a reliable source. Have a good look at the impeller. if it is badly corroded, the clearances will be excessive and the pumps ability to move water will suffer. Too much and the car will over heat.
Carl
Carl
Ozzy_UK
45
02-19-2019 03:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 12:56 PM
