Water on rear passenger floor
Have installed the pax side floor pan and will seal all seams & rivet heads with polyurethane sealant. Notice the underside of the pan was
undercoated prior to installation. Will finish work on the Parcel Shelf before top coating the underseat pans just prior to seat installation. Another concern of course is that I see a complete respray of the interior side panels seems required.. I believe it to be Biscuit but not positive. That will delay everything.
Got 16 oz Biscuit Dye from
https://www.classicdyeproducts.com/
Think it's enough to do the entire interor but seats are fine. Matches perfectly and very easy to apply. Cleaned surfaces with MEK and applied full strength with a 1 inch foam brush. Back done. Will do front and console in a bit. Lighting in photo makes it look lighter, but if you look at the shot with the seat in you'll see it matches.
Floor repaired....windows fixed & lubed. seat back in & yes the Parcel Shelf is done. Wow !
Parcel Shelf refabricated in separate thread !
LnrB (09-24-2022)
Received 9,302 Likes
foster6009
01-21-2014 07:16 AM
