What is this bracket?
Old 07-26-2022 | 09:01 AM
Yellow series3's Avatar
Default What is this bracket?
Right over the battery (1987 Series III) is a flange with a captive nut. The battery hold downs are vertical long bolts on either end of the battery so it can’t be that. Can anyone tell me what this bracket is for? Thanks.
ukborn (12-04-2023)
Old 07-26-2022 | 10:12 AM
Darrenmb's Avatar
It’s also for the battery hold down, battery bracket should be sort of t shaped, one leg either side and one goes back to that
LT1 jaguar (07-26-2022)
Old 07-26-2022 | 10:50 AM
Jose's Avatar
Darren is correct, my holdown bracket is T shaped with a very large phillips screw and lock washer attaching the center hook to the firewall.
It is a 3-way holdown, 2 vertical hooks, one on each side of battery, 1 horizontal hook over the center of the battery
Old 07-26-2022 | 11:32 AM
Son of a gun; learn something new every day. I've never seen a three point battery hold down before. Thanks for your help!
Jeff
Old 07-26-2022 | 11:57 AM
It's for all those Spirited corners and other sudden changes of direction you do, Jeff, so the battery doesn't go flying.
Jahmiata (07-29-2022)
Old 07-26-2022 | 12:25 PM
Jose's Avatar
The following 3 users liked this post by Jose:
Jag7651 (07-28-2022), retroren (07-27-2022), ukborn (12-08-2023)
Old 12-04-2023 | 09:17 AM
ukborn's Avatar
Smile
On right hand drive cars it is used for the brake pedal box
The following 3 users liked this post by ukborn:
Doug (12-04-2023), Jose (12-04-2023), LnrB (12-04-2023)
recorder72
08-23-2021 11:49 AM
ebrand
E type ( XK-E )
10-29-2015 10:51 AM
al_roethlisberger
09-11-2015 11:04 PM
jpipe
07-03-2015 09:58 AM
journeyman
10-20-2014 12:19 PM
