Where can I get a stub axle flange bolts?
I pulled my stub axle assemblies out of the differential to do the seals and one of my friends noticed that a couple of my stub axle bolts were damaged. These bolts go through the 4-bolt flange on the stub axles, through the brake discs, and through the inner axle flanges by the inner U-joint.
Anybody know where I can get a couple of these? I called the local Jaguar dealer, and they only sell the whole stub axle assembly. I was hoping to buy one used. Any ideas - maybe someone has a worn out differential sitting around for parts?
When my IRS was out, one of mine was broken. This place had them in stock and they came with LocTite (S3 type) installed instead of the holes for the safety wire.
(909)946-1809
Work
(800)231-3588
Work 2
(909)946-3398
Work fax
Address
Exotic Car Parts
923 N Central Ave # D
Upland, CA 91786
United States of America
(909)946-1809
Work
(800)231-3588
Work 2
(909)946-3398
Work fax
Address
Exotic Car Parts
Upland, CA 91786
baskervillema
10-01-2015 06:43 PM
