Where is Fuel Filter??
Typically they're under the car inside the left rear wheel. HOWEVER, that's on an XJ6. Not sure if the XJS is the same.
Here's something I found on the net:
AGain, this is for an XJ6, and I don't know if they're the same.
be super careful about both a) the fact that it's going to spit fuel all over your driveway, and b) the bolt you have have to get off is a supremely rare 12mm banjo fitting. I broke mine and to wait like 3 months before anyone came up with a suitable replacement. It's a fairly simple process though. Jack up left rear wheel (driver side). Remove wheel, and put a jackstand on the support point. Seriously, you'll be getting under the car, so don't trust that stupid little jaguar jack.
Remove the banjo bolt w/ a 17mm wrench, then unscrew the filter from the y adapter on it's rear. (it helps if you unscrew the filter holder from underneath the car [after you rmove the banjo bolt, but before you remove the y adapter])
good luck and be extra careful with that fitting.
Received 10,941 Likes
shootingbrake
09-23-2015 10:54 AM
axr383
09-18-2015 11:19 AM
