Windshield washer reservoir pump
Received 9,441 Likes
You need to contact David Bodger at everydayXJ.com.
He's a breaker on the East coast, Carolinas I think, and he posts here sometimes. Many of us have dealt with him (including me); he's a nice guy, easy to deal with and only sells the good stuff. He'll doubtless have just what you need.
The following 2 users liked this post by LnrB:
davidboger (10-07-2017),
doghead08 (10-03-2017)
Received 6,327 Likes
or sista in this case.
Received 2,399 Likes
The following 2 users liked this post by JagCad:
The following 2 users liked this post by doghead08:
LnrB (10-04-2017)
Sorry to say it but the aftermarket will probably do the same thing and maybe last longer than the original Bosch or Lucas part.
the principle is the same on all windshield washers, no matter who makes them.
if you cannot find one, try one from a Ford, they are almost identical in shape, with one inlet and one outlet, and they mount in the same place, the same way, and maybe can use the same connector.
After I sent this post on Friday..I went back outside and notice all the washer fluid was all over my driveway. so my advice to anyone in the future..make sure you push the pump all the way into the grommets or else you will waste 2.50 on washer fluid. I had to go back and take the bottle back out..jam that sucker in all the way. Then I wa good to go.
excellent doghead08, I bet it works the same or better. time will tell.
as to windshield washer fluid, my opinion is: Save your money, just fill with water from the garden hose.
I have been using nothing but garden hose water in my cars since 1970, including the XJ-6, and never had a problem. Windshield washer fluid causes stains on the paint from the blue colorant and I suspect it also clogs the pumps.
if you live in a climate where water will freeze in winter temps, just add a couple of spoons of alcohol and it won't freeze. In fact, that is what Jaguar recommended in the 1960's Owner's Handbooks. (NOTE: NOT Charlie Daniels alcohol or any of those famous ones from Scotland, me talking about rubbing alcohol).
Jose :
Good point. But OK only for those of us that live in warm or moderate climes. Not good for those who live in ice and snow company.
I messed with the pump and tank in my Jaguar. It wasn't working. the fix was not a fix. Pump worked fine on the bench. In the car, no.
Now, the one in my Jeep works really well Two nozzles that spray generously. I added water and a bit of car wash soap. works great.
I suspect any mild detergent would do just as well. Dish soap, not dish washer soap. Perhaps even a dash of laundry detergent.
Carl
Carl
@Jose. Rubbing alcohol? I had an issue driving home on the jersey parkway in a snow storm in my explorer and washing fluid froze solid. Boy did that suck something fierce. Almost as bad as driving home in a rainstorm from citi Field in queens after some ****** stole both my side view mirrors.
Received 10,979 Likes
