Windshield wiper home position
I realize that I can adjust where the park position is just by removing the arm and repositioning on the stem. But where on the windshield is it supposed to park. The higher up the more visab
ility blocked; the lower the more it hangs out beyond the wind shield.
they should park at the passenger side, not the Driver's. I think you have something upside down. Or the wrong motor, Australian and European motors park on the left side because the steering wheel is on the Right Hand side. American motors park on the Right Hand side.
My wipers have shorter blades than that but this is how they sit.
I think the idea was hatched Across the Pond where controls are on the other side of the car, so the driver side wiper is always flat. Series 2 and 3 Jags imported to Merca that I have seen all have this hang over problem rendering that wiper Useless if it's more than 3 days old, as the rubber takes a set and fails to touch the glass in the center where it's needed.
I toyed with the idea of fabricating a shorter blade for the left side to deal with this, but as I don't drive Nix in bad weather anyway, I never got around to it.
there are two ways of looking at this:
1) if you are sitting in the car,
2) if you are standing in front of the car.
If sitting in the car, and the car is Left Hand Drive, the wipers should park to your Right / Passenger side.
If Standing in front of the car looking at the wipers of a Left Hand Drive car, the wipers should park to the Left / Passenger side.
It was only the Series III cars which changed the wipers on lhd models to park on the side opposite the driver's side. Earlier Jaguars had the wipers park on the left side regardless of being rhd or lhd cars.
I brought up this question a while ago when I saw some pictures of our cars( in the USA) on this forum. Some of them were parked on the driver side of the vehicle and others (including mine) parked on the passenger side of the vehicle.
Further research showed that some cars used 15" blades on both sides which caused the overlap when the wipers parked on the driver or passenger side.
Truth be told. I solved that by using the Series 1 sizes on my Series 3.
15" on the driver side and 14" on the passenger side.
AS PER THE PARTS MANUAL I HAVE: (XJ6 1969-1987)
Series 1: Driver side #38-150 =15" passenger Side #38-140 = 14" (Parks on the left side the vehicle).
Series 2: 15" on both sides
Series 3: 15" on both sides
That was one of the reasons I brought up the question.
On a LHD car, if the wipers park on the left side of the vehicle, the distance from the left hand wiper pivot(where the arm is attached) is 20+" from the edge of the windshield, so a 15" blade works fine. The swivel point of the blade on the arm is about 7".
However, if the wipers park on the right side of the vehicle, the right hand pivot is only 18" from the edge of the windshield so the 15" wiper blade is too long.
I can’t see any reason why the wipers would not park on the drivers side whichever side that is. When you get a sudden dousing of water you would want the blade to clean in front of the driver ASAP. I appreciate that we are talking about a very short period of time but it could be important in an emergency.
That was, um, Interesting I tell ya!
Wow! I had no idea I would be bringing up such a varied opinion/option issue. Guess nothing is straightforward with our Jaguars. But still fun it is! I'll start doing some experimenting. And yes, mine is a Series II. And I know it was made for an American market. And frankly it doesn't park on its own anyways; I have to flip the switch off at just the right time. So I can probably choose how I where I want it to park with some arms/blades/repositioning changes.
Thanks all, Bill
Thanks all, Bill
I think the rationale was to have them out of the driver's line-of-sight when not in use
Well, As does Elinor, I rarely drive my jaguar in the rain. But, it's wipers park nicely on the passenger's side. On occasion, I use the Gregory move to correct the park.
At last, we get some "dry" days. But even with the sun out, it is cold.....
Carl
Carl
