Wiper motor V.s relay?
Received 10,989 Likes
Fuse, fuse, fuse. My story: 1992 Series III V12 VDP, never, ever in the rain. Wipers tested yearly. One year the wipers on testing (pulled away from the glass, of course) moved about an inch and then nothing. No movement, no sound. I checked the fuse -which looked fine, but for assurance I replaced it. No joy. Hmmmm....the column switch....looked perfect, operated as it should. Looked at and check the park switch at the wiper motor, no problem...checked all connections....replaced the fuse again, just in case. No joy. After taking Valium I decided that before tearing the wiper motor apart I would check with my Jaguar-specialist mechanic. He listened to the story and said "Mate, it's the fuse" (He is English, and he can take apart and rebuild these cars before his morning coffee: those two facts are unrelated). "But Frank, I replaced the fuse twice". "It's the fuse".
He got under the dash to access the fuse box, fiddled for 10 seconds and said "try them" . I did. They worked perfectly.
Now exactly what he did, I don't know, and instead of answering my question about that he just smiled...and before you ask, yes, I did tighten the fuse cradle arms each time I replaced the fuse.
my experience with electrical issues on these cars is that it is ALWAYS either the fuse or the connector and for both of these the gremlin is often a light coating on the contacts. Often just rotating the fuse will restore connection, particularly for headlamp malfunction.
so, the fuse first, second, third....and only then, the switch.
Received 2,399 Likes
gibbon
11-05-2017 06:53 PM
Roger Mabry
E type ( XK-E )
05-05-2016 08:30 AM
Saemetric
12-05-2014 05:56 PM
