My labal fell off this wire, does anyone know where it should go? It's on the harness that (with another connector) connects to the temp sensor on the rail. Seems to be white, which typically means +12v...
Reason: Bad title
Probably goes to the coil "+" post....or to the ballast resistor if you have one
A couple of the relays on the firewall have a white wire as well.
Thanks DD!
I'm betting it doesn't run back to the FW, as it's sourcing from there (that's where that 3 prong connector comes from *I THINK*). I've got a beater over at the local Jagguy I can go look at -- though mostly it's got crazy bad wiring, I think this one is solid.
