Worn steering rack?
Hi guys,
Today I tried to do a "toe" adjustment on the Series 1, after finally getting the castor and camber settings to my liking.
With the front wheels on slip plates, I noticed slight movement in each front wheel, when grabbing @ the 9 & 3 o'clock positions and rocking back & forth.
The steering rack was centralised and "locked" in position as per the factory manual instructions. Wheel bearings are fine with no measurable play.
Given toe-in is specified at 1.6 to 3.2 mm, probably a lot less than the above detected movement, I now figure I'm wasting my time.
Please tell me I'm not due for a rack replacement![Icon Violin](https://www.jaguarforums.com/forum/images/smilies/icon_violin.gif)
Received 9,205 Likes
The following 2 users liked this post by LnrB:
Grant Francis (09-22-2021),
Jose (09-21-2021)
The following 2 users liked this post by redtriangle:
o1xjr (09-22-2021)
Grant Francis (09-23-2021)
Jose (09-24-2021)
DRAT!!
Hi everyone,
This is what I have bought
https://www.ebay.com.au/itm/15243416...m=152434168801
Turns out that, after absorbing the excellent advice from all, I discovered my outer tie rod on the RHS, and inner tie rod of the LHS both have play in them, so for about $200 Ozzie dollars I can completely overhaul both sides. As for Elinor's query, the outers have the greasing valves which is what I prefer too. BTW, the "bible" says they can all be replaced with the rack in situ (thank you God) and the big nut for the inners appears easily accessible, so no special tools required. Thanks Jose for the video anyway.
https://i.ebayimg.com/images/g/jUgAA...E0N/s-l500.jpg
The following 4 users liked this post by redtriangle:
Here is the ebay listing for the inners. Being aftermarket, I guess the part numbers what not mean a lot in other countries.
https://www.ebay.com.au/itm/18445260...gAAOSwqvRfZE0N
Received 2,399 Likes
bjzwissler
11-07-2016 09:24 PM
