XJ S3 sunroof, 1-way or 2-way
I have an 81 XJ6 S3, with a sunroof than can both go back as most do, but also tilt forward/open the rear. Handled with the same switch and relay(s?) that I can hear and feel click sitting in the roof to the right of the inside mirror. My friend has a much more posh 85 VandenPlas XJ12 but he says his sunroof can only go back, not tilt forward. I suggested he looked at the relay(s), but he has no relays in that area. Does anybody know which type of sunroof was factory and where relay(s) are?
Received 10,876 Likes
The slide-only sunroof, such as your friend has, is the Jaguar type. It shared the power window relay.... which is at the extreme RH side of the dashboard.
Your slide-tilt sunroof is an aftermarket installation (common back then). The details of the switching circuit will need to be discovered by you :-)
Jag7651 (01-14-2023)
