XJ12 on Bringatrailer
I don't recall seeing too many in this navy blue, but it really is striking!!
No Reserve: 1978 Jaguar XJ12L | Bring a Trailer
No connection to the car, just thought I would share.
Sarc (09-24-2015)
I think you got a lot of car for $7500.
Surprised at the number of posts on the auction site from 'apparently' previous XJ12 owners. Given the low numbers manufactured, many of these people may have once talked to someone who knew someone who owned one!
The convincing story was the one about the old lady getting 8 mpg. I've only owned one XJ12 and it was rare to get into double figures on fuel consumption.
Enjoy it.
Enjoy it.
Thank you for the warm welcome. I love mechanical things and have wanted a V12 for a long time. I find many cars are reliable if you maintain them and, more importantly, USE them regularly.
As soon as the car is delivered, I plan on getting the AC sorted. It is a must in Florida 2/3 of the year. The AC looked pretty complete from the photos, so I hope the problem can be identified easily.
Does anyone know of a good AC or other shop in Orlando? Darrenmb? I am new to British cars and I do not have the AC equipment. I think I can handle most everything else that may come up. The forums are very helpful.
Thanks again.
Glenn
Thanks again.
Glenn
Thanks again.
Glenn
Thanks again.
Glenn
Received 2,399 Likes
Glenn:
It sure looks nice. A lot of fun coming up.
I'd try the easy first. If feasible. Has it been converted to R134a? If so, just get a couple of cans from the parts place and charge it. It just might work. I seriously doubt that it has anything in it Freon or R1341 The caps on the pipes will tell which.
OTH, any decent AC shop can check it out and charge it if it has no leaks. If it leaks, they will not, even if small. You can???
HF sells the manifold and pump for a very reasonable charge. Check on line for a manual on their use. I've a couple of those. One an older one by a major oil company for it's dealers to use!!!
Carl
Carl
Darrenmb: I work right around the corner from the Classic Jaguar place! I forgot it was there. I will try to make the breakfast if I can. I will need to drive something else this time.
JagCad: It is most likely R12. I will know more when it arrives. I will look into the equipment and doing it myself.
Thanks.
Thanks.
Received 9,203 Likes
audibabba (10-03-2015)
Darrenmb: I did not make the British Car breakfast on Sunday. There was some nice weather, so I went flying, instead.
I did check out the Classic Jaguar place on 436. It turns out the owner is a good friend of a guy I work with, so I am going to try them out with the AC repair. The owner has worked on Jaguars at the local dealership for over 30 years before going out on his own. They only work on Jaguar and it is right around the corner from where I work. I will let you know how it works out.
LnrB: I will look in to that refrigerant mix further. I have read articles where designers were trying to deal with the combustibility of the propane and butane to make it safer with changes to the AC designs. That was a few years ago, though. The articles did not mention the mix was better than R134a. I gathered there was nothing that would match the efficiency of the current refrigerant. I guess I misread the article (or misremembered).
Thanks.
Thanks.
LnrB (10-06-2015)
It Propane was so dangerous, there wouldn't be Thousands of relational vehicles on the roads with propane refrigerators and cook stoves, and bottles of propane hanging off the tale gates. It's flammable, true, but so are ALL refrigerants. That's why sniffer guns work. They use a flame to find leaks in the system.
I do know from my own personal experience, that R134a sucks pond water when put into a system originally designed for R12. I had that done professionally to an Ancient Chrysler once, and it was a Complete Disaster! When weather was Really Hot, like it gets in California's Central Valley, it was only a little better than parking in the shade.
Husband found this HC-12a, evacuated the system and put it in for me, and Shazzam! It would get COLD again!! Even on the HOTTEST days! So, that made a believer out of me. However, you must do whatever you think is right for you.
There is room to think. My past experience in insurance claims taught me a lot.
One of my cases involved a moderate fire in a rental apartment. The source was under the refrigerator in the kitchen. My consultant and I got close but could not quite prove the frig was defective and the cause. And additionly, a major maker refused to admit it was their product. I left, but with a strong belief that the mixture of oil and Freon escaped the compressor and was ignited by the blower fan.
In another, a newly introduced Ford "little Bronco" caught fire. A leaking exhaust coupler ignited a transmission leak!!! According to the fire department and witnesses it burned hot!!!!
An way back, a farmer was in has field in a new 56 or 57 Ford pickup. first year of the automatic for trucks. Air "cooled". No pipes to and from the radiator!!!
The fluid got so hot it ignited out the filler nd burned under the hood, good.
So, in addition to gasoline, we do have flamables aboard. But, in the passenger cabin? Answer, yup, we sure do, the refrigerant....
Next summer I just might try that HC12. As my Jaguar was R12, it cooled nicely then. Now its system is a mix of jaguar and GM, and I've read of mixed opinions of R134 in R12 systems, I've held off. other reasons as well...
Yeah, it can get durn hot in Norcal!!! Durn near cooked in one trip through LnrB's part of the country.....
Carl .
Carl .
Sounds reasonable to me. Well, mebbe not Wart? it like my Jeep s designed for R134. As we know, most cars nowadays are.
My 94 Grand Cherokee is. Now that it's leak vanished, it cools splendidly, even on super hot days. I avoid running around on the peak hours, if possible.
My test is to run it wide open. Hold a finger to the outlet frill. when right, it is biting cold.
Carl
Carl
Do HC 12aŽ, HC-22aŽ and HC 502aŽ Require Retrofitting?*
The use of our refrigerants to replace CFC's or HCFC's requires minimal retrofitting (change to service fittings). All other applications require no retrofitting. Our hydrocarbon refrigerants are completely compatible with all the materials and oils (mineral or synthetic) in all systems. The cost and environmental savings can be substantial!
The above quoted company does not sell in the US, but it IS available in this country. Husband found in online but he's not sure where at this moment, maybe in Georgia, he merely evacuated my system and put in the Propane. If you absolutely positively can't find it, he'll look through his records but that was some years ago and it will take time.
Some compressor companies say they won't stand behind their compressors if Propane is loaded in the system as if it made more pressure than anything else which it doesn't. He followed the directions on the can. I didn't blow my compressor and I haven't heard of anyone who did. It's weasel words.
~EDIT~
Husband found the site where he got the Propane refrigerant. The page is still active; says for US residents order online.
http://www.duracool.com/
Another company in Nashville, TN:
http://bennettsupply.net/HC-12a.htm
audibabba (10-09-2015)
