xj12 engine swapping and other questions.
I picked up a 1990 xj12. Not shure why the 88-92 series three xj12's are not included in this forum. And I did'nt see anouther spot to post so here I am. I have long dreamed of owning a series one XJ6. But this Xj12 came along very cheap.
I need to either repair or replace my motor. And swapping in a running motor sounds easier to me. I was hoping to find out if series 1&2 v12's can be used without much fuss.
Also. I'm thinking about some performance mods. Does any one know of a manual steering rack that would fit a series 3? I would like to go manual steering with a large wood rim steering wheel.
Received 10,880 Likes
An earlier V12 would bolt in Ok but you'd have to work out the details ....different F.I. system, different ignition system and probably a slew of other little things. Plus....anything prior to mid-77 had the Borg Warner trans instead of the TH400. I think you'd run into a bolt pattern issue. Plus plus....the early "pre-HE" engines sucked up even more gas the the one you've got.
I'd look for a correct mid-81 or newer HE V12, personally. Shouldn't be too hard to find as the XJSs had 'em...and even then the early 80s version had some minor differences.
Don't know where you'd find a non-power steering rack. The car would be a bear to drive even if you could.
You're posting in the right place. It's just that the section heading isn't quite accurate. It should say XJ6 1968-1987 and XJ12 1972-1992
Hey thanks for the info.
I guess I'll try to narrow my search to as close to 1990 as possible. I'm just off on vacation now. Sometime in December I hope to pull the motor and spread it out across the garage floor and see whats let of the one I have. Also I have a friend with an auto wrecking business. Maybe he can help me find motor with the networking system they have.
Yes I imagine if the gear ratio on the manual steering was not right it would be a handfull. But for example I once had an old two ton Ford truck with manual steering and it was easy enough to drive. I was just looking to reduce weight and transfer more power to the rear wheels.
philwarner
09-05-2015 10:05 AM
